MacOS Permissions / Volume Not Mounted Issues
Hey all!
Wanted to run this issue by you and see if anyone has a better solution:
  • new Flame 2023.2 installed on a new Mac Studio
  • everything seems fine
  • try to import a clip, caching fails
  • went through permissions, tried giving more access to services
  • all of a sudden, I can’t open the test project or create a new one
  • Create new project dialog says: Volume is not mounted
  • no mater what we tried, couldn’t get it to work
  • even deleted my local account and created a new one
  • however, everything works from Admin account, my local account does not have Admin access
  • finally, we deleted the Storage folder, created a new one and that worked
Anyone encountered this issue? Would like to know if there is a better solution than having to create a new storage if it happens again.
Thanks!
did you go through System Preferences/Security & Privacy/ Privacy tab then select Full Disc Access and after entering your password, scroll down the list of services and tick every flame related one? (AdskAccessServiceHost, iffsWiretapServer,Wiretapgateway - there may be others but i don’t remember)
that might help!
Thanks! Yeah, pretty sure we went through all of those.
Main question is why would adding any access or permissions “unmount” the Storage Volume.
not a clue!
just remember having to allow all those sevices to have access before i could see drives and projects and do anything in Flame.
Also worth checking you did the same in the Files and Folders settings (just below the Full Disc Access settings)
So… not open up any old wounds here or anything, but did you ever get this resolved @Igor ?
I was trying to help a colleague Flame on his mac and his issue seemed to be that the drive wasn’t mounted… but it was mounted… What I found was that I could see the drive mounted on the mac desktop. Let’s call the drive “Flame Drive A”. I could clearly see the drive on the mac desktop with the label “Flame Drive A” but Flame couldn’t.
When I went to terminal and ran “df -h” I could see the drive was mounted, but the mount point was listed as “/Volumes/Flame Drive A 1”. For some reason the drive mount path and it’s name were not the same. I’m not sure why this occurred. Usually in MacOS, if you see a “space-1” after the name it’s because it’s a copy or there is already something using that name. I couldn’t see another partition mounted or any reason that the mac added " 1" to the mount path… but it definitely did.
So I edited the path to the media storage volume to include " 1" and then the project was able to load without issue.
Maybe someone else has seen this before?
Thoughts? Feelings?
I genuinely think this is a Mac thing and not a Flame thing, but if you run Flame on the fruit computer… you might run in to this.
Here is the fix last time this came up:
To avoid this behavior, remove stale mount point and reconnect managed media
Note: Always be sure of what commands you are running. The below procedure is a permanent action and can have consequences.
Via terminal, list current mounted drives in /Volumes
ls -al
Look for any drives with " 1" at end of path
ex:
drwxr-xr-x   2 flame  staff   64 Oct 25 14:21 AutodeskMediaStorage
drwxr-xr-x   2 flame  staff   64 Oct 25 14:21 AutodeskMediaStorage 1
Verify that drive is mounted incorrectly with ‘mount’ command
mount | grep Volumes
Relocate stale mount to /var/tmp
mv [mountname] /var/tmp/
Create symlink to new [mountname]
ln -s [mountname]\ 1 [mountname]
ex:
ln -s AutodeskMediaStorage\ 1/ AutodeskMediaStorage
Restart Stone + Wire
/opt/Autodesk/sw/sw_restart all
Thanks @randy and @motoronlysync ! Much appreciated!
Yeah got resolved, TBH … IT ended up handling it. I believe they had to mount a new Volume and trash the old one. Has been working fine since … knock on wood.
