Matchbox shaders disappeared from Node bin
Hey all. I recently installed the Logik Matchbook shaders and all matchbox shaders vanished from the node bin in batch/action.
The shader path preferences is set correctly to /opt/Autodesk/presets/2023.3/matchbox/shaders/
I can still access the shaders when I drag in a matchbox node and manually browse. I’ve verified that the shaders are in the above location. I’ve tried reinstalling the shaders via the Logik portal.
Any suggestions? Running Flame 2023.3 on Linux.
Is there anything here that can help you?
Thanks! Yes can confirm that deleting the tpo.cas shader fixed this issue.
