ML Face Maps can generate a UV map:
If you bring this into Action, you can use it as a UV map and it sticks Ok:
But if you wanted to use the UV map to stick some red dots on the face, what’s the UV map using as reference?
Through some trial and error, I put red on the eyes, nose, and lips:
So clearly Flame has some map in mind.
And no, it’s not MLHumanFaceTemplates, that looks like this:
So what unwrapped UV face template is Flame using under the hood?
-Ted
