MOCHA 3d Tracking
Hi,
MOCHA pro 2024 OFX has a mini version of Syntheyes in it.
I can only see export options for FBX unlike “big” syntheyes having the export to Action available.
When I use the FBX export option I only get to the camera data. Cant see any points or axis’s.
What am I doing wrong. oh if you think its a limitation because its little syntheyes then why do they support nuke.
It can export feature points. But you have to select them in the right hand tab, and during export you have to check the box to export features.
You actually don’t even need to select them if you just want to quickly export an FBX with all the points.
Just select the “Export points as” dropdown and switch it to “Nulls” rather then the default, “Single mesh”.
