Morph crazyness
Hi there
New ml morph tool is really great and saving my life with all those fancy edits, and long sequence shots.
But i got crazy with range management. in batch, it is limited to its range, setting by the lenght of the foreground clip. and i cant force this range up. So, when my keyframes are out of this range it just does a cut. So, i have to mux down and up to fit my keyframes inside this range.
And if i plug a clip with another length, range and keyframes are changing, and also, by changing the start frame of my batch, it may change the keyframe position.
So when i have a lot of small clips to fit together, my brain is doing gymnastics with frame numbers.
cheers
in flame 2025.2.2
I like to time stuff like that from the timeline then promote to bfx fwiw
