Offset Timecode in AAF
Hi all,
Wondering if there’s an easy way to offset the timecode of clips in an AAF? I’ve got a bunch of Phantom footage that is exactly 3 hours off in the AAF vs the transfer we’ve received back.
Thank you for any help!
Under the Conform tab select all the phantom clips and then click into the Source In column and the calculator will pop up, type in 3:00:00:00 and then click either “Add” or “Sub” depending on offset. That should do it.
This did the trick!
Awesome! I find myself doing this a few times a week.
