OFX plug in crashing
Hey All,
Wondering if anyone has encountered this. I’m installing Flame 2022.1 on OSX and I have the error message saying “An OpenFX plug-in caused a crash”
I looked at the log (in pdf form below) can anyone tell me which one it is and how to ignore it by adding it to the cf_ofx_ignores_list.cfg
thanks so much for any knowledge in solving this issue
flame20221_hardaves-ipro-7_app.pdf (74.3 KB)
Hi @Hardave,
I hope you are well,
Would you mind sharing the corresponding shell.log?
Thanks,
Yann
Hello Yann,
Thanks for responding. I have uploaded a PDF. I’m having trouble uploading the actual log file to the forum
I have also emailed you directly the log file so you can take a look at them.
thanks for taking a look.
Hello,
To close the loop on this discussion, the plugin causing the crash was BCC+.ofx.bundle.
Thanks,
Yann
Thanks Yann!
To avoid it from loading I entered (BBC+.ofx.bundle) into the “cf_ofx_ignore_list.cfg” file under opt/Autodesk/presets/2022.1/status/ folder and Flame bypassed on start up.
Just had this error in 2026. I had to edit the cf_ofx_ignore_list.cfg to ignore Mocha Pro and Red Giant but still want to be able to use these in OFX. Any advice from the pros or developers here on how to fix this?
Thanks!
Which version of MochaPro is installed on your machine? There was a third party component issue with MochaPro and Flame2025 (and laters) last year but this was fixed by BorisFX in MochaPro 2024 (release 11).
Mocha Pro 2025 v12.0.2, and having the same issue with Red Giant 2025.4.1. Whenever I #comment them out of the ignore list, I get a crash
