I have a paint stroke that I want to animate. When I select edit on the stroke and go under the animation menu nothing shows up. All that is there is “scene”. This is on Flame 2023.2. I have tried a new user which doesn’t help. Any ideas?
Check your filters on the left pane. It might not show up if there are no keyframes yet.
make sure the stroke has a range, rather than just a single frame
It actually ended up being corrupted user. I had the frame range to sequence which was set to 100. Thanks for the replies!
