I’m using flame on my Mac - click pen drag copy is working - oh welcome back dear friend - why cannot I get this working on Teradici?
@randy how do I get it to work?
Bridge the Wacom in Teradici settings.
I often do and still can’t get it to work
Last ditch but check in flame preferences and see what the input device settings are and if they’re set to host settings then check the Wacom tablet preferences for pen settings on the client machine. Chances are the button rocker is set to mouse 4 and 5. Set it to middle and right click on whatever sides of the rocker you prefer.
I’ll give it a look in the morning - the pen is deffo set to middle click though - thanks
I’ve got a similar problem using Parsec. When I use the pen and tablet locally, it’s fine. I can do a copy with shift - button 4, but when I use it over Parsec, I only get the contextual menu pop-up. Also for some reason, when I do Control-Tab to bring up the effects ribbon, it doesn’t work. I have to do Tab-Control, and it pops up.
Works for me, mac controlling a linux box. I’m assuming you haven’t connected your wacom. Paint won’t work with pressure either if you haven’t.
The machine thats running flame is a mac with no tablet connected. Pen pressure works fine from the client machine using the latest wacom tablet.
I have no clue @johnt. If you are using an approved Wacom tablet on the client side, and matching graphics agent and software client, and you run the 2-3 lines of installation, it’s literally hard as fuck for this not to work.
Ah. That could be it. Matching graphics agent and software client. By that I take it you mean version numbers? My software is probably the latest beta. It usually is. Let me check on that.
I have he same issues on Parsec. Would love a workaround/solve.
@randy I’ve now got matching match software both ends. What are the 2-3 lines Of installation?
