Python: Create social format timelines from existing timelines
Many of us live in a world now where we have to create these timelines for every project.
Sadly, duplicating a timeline and reformatting it kills any connect segments you might have which makes that method not ideal.
Creating empty timelines in the new resolution, dragging the 16x9 timeline into that and naming it all…maybe fine for one or two edits but if you have a ton, that’s a lot of wasted time.
Here’s a hook that’ll do it all for you…other than the unicorn of re-racking but life can’t be all sunshine and butterflies.
How To Use:
  1. Select sequence(s)
  2. Right-click > Social Versions
  3. Select which of the 3 flavors
  4. Let it run
  5. Use any of the amazing renaming tools to re-jig the name to your workflow
What It Does:
  1. Creates a new reel named height x width.
  2. Creates a new timeline with the existing name but with height x width appended.
  3. Puts all the layers/versions from the selected sequence into the new one.
  4. Saves you a shit ton of time
I was on the fence of doing 1x1, 4x5 or 9x16 but opted for the resolution instead. Open to changing that if the hive mind would rather that.
Download:
social_versions.py (v0.3)
Awesome, thanks Kyle! Will give this a go on my next project.
Ill be trying this out today. Sounds amazing!
holy shit this sounds awesome will give it a try. you rock @kyleobley
@knhn
works great for me @kyleobley (we are on 2023) - so nice to take a whole row of conforms and boom.
Does this maintain the links on connected segments?
thanks
sure does.
Most definitely does!
Time to upgrade friend. 2025 has so many good features.
On a related topic, client just sent specs for a job: Our long understanding of 1x1 and 9x16 has just changed.
Hello Darkness, my old friend.
what is new here? we’ve been delivering a lot of 1x1 at this resolution. same with 4x5. often times we gotta do the full monty of all the 'effin social res . maybe i misunderstood…
I’ve been delivering at 1080x1080,1080x1350 and 1080x1920. This is a first time I’ve been asked for this size. And I check through these specs pretty often.
Same. I want us to get to 4x3 1920x1440–Spirit 2k and then we’ve gone in a massive 20 year circle jerk.
Not for nothin’, but academy ratio has been around since the 1930’s.
For sure. I’m angling more towards constantly changing “standards”… the Spirit couldn’t do a full 2048 and we were off to the races.
This will affect how we work in TVC. We’re still Mastering to HD for the most part, unless clients specifically request 4k at the start. Social deliverables come from this… 1080x1080 and 864x1080
We could probably resize these files up to 1440 and no one would notice but I think we’re gonna have to start mastering at a 2048 or 2160 vertical resolution.
I love it
This is us. We are going to keep doing so until someone tells us otherwise. Fuck Meta.
