Hello
Is it possible to rename (under macOS) the Framestore (external Thunderbolt portable SSD), which I mistakenly named ‘Flamestore’ in Flame 2021, to “Autodesk_Framestore” before mapping this Framestore for use in a freshly installed Flame 2027?
vfx@iMac-2020 Logs % mount
/dev/disk2s1s1 on / (apfs, sealed, local, read-only, journaled)
devfs on /dev (devfs, local, nobrowse)
/dev/disk2s3 on /System/Volumes/Preboot (apfs, local, journaled, nobrowse)
/dev/disk2s6 on /System/Volumes/VM (apfs, local, noexec, journaled, noatime, nobrowse)
/dev/disk2s5 on /System/Volumes/Update (apfs, local, journaled, nobrowse)
/dev/disk2s2 on /System/Volumes/Data (apfs, NFS exported, local, journaled, nobrowse, root data)
/dev/disk1s1 on /Volumes/Untitled (apfs, local, journaled)
map auto_home on /System/Volumes/Data/home (autofs, automounted, nobrowse)
map -hosts on /System/Volumes/Data/hosts (autofs, automounted, nobrowse)
/dev/disk2s1 on /System/Volumes/Update/mnt1 (apfs, sealed, local, journaled, nobrowse)
/dev/disk3s2 on /Volumes/Flamestore (hfs, local, journaled)
/dev/disk3s3 on /Volumes/VFX-Work (exfat, local, nodev, nosuid, noowners, noatime, fskit)
Thank’s!
