Saving to a Library
Just switched to 2021.2
When saving a Desktop to a Library that already had a Desktop with the same name, I used to get a prompt allowing me to Add, Replace or Cancel. This would allow me to save over the previous Desktop, ensuring that only the latest copy was in the Library. This would happen regardless of what “Duplicate Name Check” was set at.
The new behavior is just to add the Desktop with the exact same name, making it impossible to tell which is the latest copy.
Is there a preference to return to the old behavior, or is this a bug?
Thanks!
I get the correct options and when I select replace it overwrites the folder.
Have you tried creating a new preferences/ user
@Dwklink Have you found a solution to this? It’s happening to me as well. I’ve tried creating a new user but no luck.
