Setup import option using Python
Hi,
I would like to set the No Cache and Sequence option (vs frame) to the mediahub before to load a clip using python.
I try to understand how to setup it using
class PyMediaHubFilesTabOptions( )
It seems to have all the feature I want, but I can’t manage to make it works.
Is it possible ? Can somebody share an exemple ?
Thans
Franck
I’m pretty sure that you just set those options and then check your preference files.
Then you can just copy that pref to every user.
Or there may be an ENV VAR?
Let me check:
It’s got to be something to do with:
BUTTON : [Frames] MediaImportSequenceMode(ON)
BUTTON : [Cache] MediaImportStoreLocalCopy(ON)
BUTTON : [File Sequence] MediaImportSequenceMode(ON)
BUTTON : [Cache] MediaImportStoreLocalCopy(OFF)
Can you extract those attributes with your python script?
Salut Phil.
I want to change these options via python on the fly.
I need to import multiple open clips. I don’t want to cache them and I need to be sure the user didn’t turn on the frame option.
I need to set back the button as it was after the import.
All of that in python
Thx
F
I couldn’t see the method either.
Sorry brother.
Fred !!!
Stephane !!!
:wink:
Salut Franck!
The current documentation does not provide much examples but the listed functions work.
If you want to enable the File Sequence mode,
flame.mediahub.files.options.sequence_mode = True
If you want to enable the Frame mode,
flame.mediahub.files.options.sequence_mode = False
If you want to disable Caching,
flame.mediahub.files.options.cache_mode = False
Hopes this help.
Super.
Merci stephane !
It’s exactly what I was looking for.
F
