Anyone else having issues getting Silhouette 2024 to load via OFX? For some reason when I try to launch it, Flame freezes and I have to kill the terminal to get out. I seem to remember it autoloading in flame 2024 and the window just coming up, but I have to select the plug in now like mocha… I can run silhouette as a standalone, just not as an ofx.
Rocky 9.3
I’ve tried installing the plugin and the standalone with dependencies. Not sure what else to do here…
Yes, there was a bug a while ago, where it wouldn’t release some memory or something. But I thought that was fixed. Maybe @marcopaolini can provide insight?
I used to have an issue where I’d have to exit Flame after every time I used an instance of Silhouette in a Batch, otherwise Flame would freeze up. I haven’t had that issue in the last couple of Silhouette releases though. I assume they fixed the memory leak.
@snacks Can you provide me with the following logs from /Home/.cache/BorisFX/ Silhouette 2024 after the hang occurs: silhouette.log, plugin-flame.log and server-flame.log?
Sure thing. I’ve been working with Victor and he has them as well. Attached. plugin-flame.log is a 0kb file with nothing in it. Here are the other two.
Also having issues with SynthEyes. I get this when I try to launch it:
(SynthEyes:740948): Gdk-ERROR *: 14:21:09.452: The program ‘SynthEyes’ received an X Window System error.
This probably reflects a bug in the program.
The error was ‘GLXBadContext’.
(Details: serial 3487 error_code 158 request_code 152 minor_code 6)
(Note to programmers: normally, X errors are reported asynchronously;
that is, you will receive the error a while after causing it.
To debug your program, run it with the --sync command line
option to change this behavior. You can then get a meaningful
backtrace from your debugger if you break on the gdk_x_error() function.)
./SynthEyes.sh: line 34: 740948 Trace/breakpoint trap (core dumped) ./SynthEyes $
[root@vxfhost SynthEyes]# [ERROR viaduct::backend::ffi] Missing HTTP status
^C Archive.zip (3.3 KB)
@snacks We can reproduce the issue here with Flame 2025.0.1 running in Rocky 9.3 and are working on a solution. The issue seems to be specific to Rocky 9.3 as Silhouette 2024 runs as expected in both Flame 2024 and 2025 both in Rocky 8.
