SlateMaker question
Has anyone ever had this result while running the slatemaker script? The script appears to run and saves the text files into the temp_slate_folder I setup on the file system. My prior experience was that the script save the clips with the text into a nice little place within flame. Not sure if the problem exists between the monitor and the back of the chair, but I figured I’d ask and then pour another coffee.
thanks in advance
Captura de Tela 2021-01-29 às 13.40.22
Hi! You need disable this options in Preferences> General. Because the script need write information in Media Panel.
Will.
It was unselected. Still get same result.
