mamadat
December 22, 2020, 2:36pm
1
Hello all
First of all, please understand that I am not good at English.
when use the ‘substance noise’ node and ‘substance splatter’ node in the flame,
the ‘f4 result view’ appears as a green square.
It’s normal to see a noise pattern, but I tried to adjust all the options inside the node, but I couldn’t find a solution. What’s the reason?
Is my system a problem? Or is the program the problem?
I attach my system as on image.
please help me…!
randy
December 22, 2020, 3:44pm
2
Welcome @mamadat !
@greg , am I remembering correctly that you saw something like this? Or was that lens flares? Same deal?
greg
December 22, 2020, 3:47pm
3
Yeah, it’s some problem on Adobe’s end but I believe this is supposed to be fixed in the latest Flame update. I don’t have access to check now but I’m pretty sure if you update flame, it will work.
randy
December 22, 2020, 3:50pm
4
Which version of Flame are you using @mamadat ?
By the way, your English is excellent!
mamadat
December 22, 2020, 4:09pm
5
Thank you!!
I’ll have to update it.
greg
December 22, 2020, 5:57pm
7
Are you using the free education version of Flame? Autodesk doesn’t allow that version to use updates. If you are, then I don’t think you’ll be able to use Substance in flame.
Peter
December 22, 2020, 10:13pm
8
Action Lighting FLME-53499 Lens Flare and Substance elements appear as green squares on the latest MacBook Pro 16-inch.
mamadat
December 23, 2020, 1:08am
9
Yes, I’m using an educational version. @greg Thank you for your answer. I’ll try to reinstall the latest version.
mamadat
December 23, 2020, 1:13am
10
@Peter Thank you for your answer. According to the page, The bug was fixed in version 20.0.2. I’ll try reinstalling the higher version. Thank you.
