Troubling text in terminal during render
Hi guys/gals… I’m getting this message in terminal for every frame that renders. Linux Flame, 2021.1. (I know…)
Flame is running ok, I just sort of noticed it glancing at terminal. It adds a new line every time it progresses a frame.
Thanks in advance!
If it makes you feel any better, I see this a lot.
I don’t know what is means. Good or bad but at least we are not alone.
Yep. Same here.
I think a while back I was told this just happens, nothing serious, ignore it.
Depending on your hardware (I’m guessing Quadro under Linux) it might slow you down after a while. I have had to do a hard reset several times…
Same here, I see this message daily.
Nothing to worry about
Yep, I probably have to restart about 5-6 times a day.
