Unable to cut node connection in BFX/Batch
HELP.
Something weird has happed to my flame. In any batch in any project I cannot cut a node connection in schematic view. Same issue using mouse or pen. I can cut node connection in Action, just not working in batch/bfx. No red line. Control draw shows the red bounding box. Restarted twice.
I’m going crazy. What could it be? My job has come to a holt.
  1. OK I found the problem
  2. [1:35 am]
if you have this config set in batch prefs you lose the ability to cut in select mode:
When Auto Parent is disabled, you need to select the Connect tool instead of the Select tool to create connections and sever them.
