Hi everyone,
I want to delete the files in Workspace/Cache
However it’s hidden and can’t see it in my library.
If I’m not mistaken I think there was a way to see hidden libraries.
Would anyone know how to view and delete files from the hidden library?
Thanks in advance
Bump.
I have the same issue, (2023 on mac).
Nothing in project but loads in workspace/-Cache_ which I’ll like to remove.
Curious
does running a vic clear anything out?
You can manually clear the library via the Push Button in Cache Life Span section of the Batch / Batch FX tab in the Preferences Menu.
no, I’ve run it several times.
Tried that, no difference.
Hello Paul, did you ever get to the bottom of this? I have the same issue
Thanks!
kily
8
I followed this guide to free space when flush button does not delete frames from cache library:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Unable-to-remove-Batch-Cache-frames-in-Flame.html
Some thoughts:
-I quit flame and I stop s+w service.
-I don’t need backup the clip library (step 4)
-I execute a vic command before of start everything again.
I’ll have to search back through my emails, I had help from support
Thanks! I will give this a try when I’ve finished my current job
