2025 and 2024 on Linux
Hello hive!
Especially @randy :slight_smile:
I have recently installed fresh 2025.2.1 on RL 9.3. Now, I have an ask to work on 2024 version… I’m scratching my head. Will 2024 work with RL 9.3? Also, I remeber the golden rule of install the latest version last.
Any thoughts?
Thank you!
Nope.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/flame-2024-sysreqs.html
Thank you! I’d assume the the right way is to rollback to 8.7 install 2024 and then install 2025. Am I thinking right?
Actually at this point it would be smarter to do 8.10 but you do you.
When I upgrade I install a new hard drive and I keep the previous drive in the machine. If I need to use an older version I switch my boot drive and restart. I have 9.3, 8.7 and I think 7 something along with the appropriate flame versions. Theoretically you could do a fresh install of an older version without having to re-install 2025 again.
This is absolutely the way to go @ytf !
