3 green boxes, resize does not work anymore
Hello,
played around with resizing to an other aspect ratio in Tools and surprisingly now there not only one/1 green “box” but even three/3 and I have the impression that resizing to the desired AR does not work anymore properly.
Any ideas what could be the problem?
Thank’s for your help!
Joe
What do you mean 3 green boxes?
The 2 boxes near the edge of frame are the safe title/action guides (not interactive).
I just learned today, that viewing the input inside resize will show you the framing in an interactive way.
Julio’s right – the solid green boxes are only guides for safe title / safe action. If they are confusing, you can disable them in the grid menu on the right.
The dotted box is your adjustable reframe. It appears that the 1.5 aspect ratio is set wrong if you want maintain the original HD aspect ratio. To change it, I’d go to ratio and set it to 1.778. Keep the scale set to proportional to maintain the AR.
You may also want to change resizing ‘letterbox’ to ‘crop edges’ if you want to lose the pillarbox.
Now I do understand it:) Thank’s to all of you for the help!
