3D Tracking Query
@MikeV you fucking god.
I’m ashamed to say I just noticed this had been uploaded the other day. It’s rad! Thanks @MikeV !
Also, note to self, check the available scripts often, there’s probably something (or many things) in there that will make your life easier!
Hi. Appart from being “oriented” (center or plane) when created from several tracking points, would someone point me the benefits of locators, compared to axes? Thx.
Does this function available in the camera analysis node I don’t see this when I try and do it there?
I’m not sure… I haven’t tried looking to be honest.
you can point-snap axis nodes to them, making spatial placement quick, as well as let you try out different points quickly.
You also cannot move locators and they show up as a single node in the schematic vs ninety axis nodes to group and hide away. So less error and less mess, two things I’m prone to.
Thx Andy for that explanation.
Isn’t it also possible to snap extended vertices to these locators? I think so but can’t be sure (not in front of the machine)
you should be able to, yeah.
Hey man… is this still on the portal?
Edit: it’s there on the site but didn’t show up on the portal. Manually installed.
Good catch. I just added it to the portal with a quick little update to put the menu at the top level of the Action right click menu for Flame 2023.2.
Thanks bud :pray:t2:
