Is there a script to transfer (create) all the conformed shots of a clip, to individual folders (named after each segment) in Library?
I don’t know of one, but you could do this with publishing on export.
Not at the machine right now, but isn’t there a Batch Groups button in the Conform tab to do precisely this?
Check out the Create Shots script on the Logik Portal. You can setup custom folder structures that can be created for each shot.
Mike
Thanks a lot Mike and Randy
