I’m trying to get the this color transform to a Nuke artist:
/Applications/Autodesk/Synergy/SynColor/2019/transforms/gamma/Linear_to_Video–legacy-viewer.ctf
I tried exporting the .lut file from the Color Management node, but that crashes Nuke.
I tried Lattice but I’m getting weird colors when I import the .lut file…
It`s not possible to correctly transfer color transforms to some kind of LUT format, because you hit an annoying lut limitation - clipping. LUTs 99,9% of the time are defined between 0 and 1, and you need to take into account numbers above 1 when you work with linear gamma.
Good news - if you need to make your Nuke viewer behave like old Flame/Smoke viewers just change your viewerProcess setting in Nuke from default sRGB to rec709. Basically what it does - applies gamma 2.4 instead of 2.2
