Flame 2026.2.3 on Mac.
Flame crashes immediately after a prores gets exported. Doesn’t happen every time, but often enough. This is happening throughout our facility.
Anyone with similar experiences? Any solutions?
I have seen this: try exporting with the “foreground” option on
oh sorry forgot to mention - this is always with foreground on.
Send your logs to autodesk
Nobody here knows how to fix your localized problem
Open service monitor and switch to the tab where you can collate and export your logs
Send it to autodesk.
Superstitiously I wonder if you are overwriting old pro res files on an smb mount.
Same. Annoying
I’ve been getting this a lot with 2027 and 2027.1, on linux.
I’ve got into the habit of regularly flushing the GPU, which helps a lot
FWIW I went back to 2026.2.2 and haven’t had any issue exporting.
