Hi, i need to use the crok particle trans for a 32 frame clip. What is the timing used for? It is set to 1. How do i create a transition of 32 frames? I cannot control the timing of the start and end of the transition. I’m in a bit of a fix… Please help… Thanks on advance
I suggest some trial and error might be required @Deepakpais .
The Timing value appears to refer to time in seconds. I used a value of 1.65 to get a complete transition over 32 frames.
Ok, thanks mate
