Flame restore issues in 2024 (Mac OS Big Sur) - SOLVED
Hi there - has anyone had any issues with restoring projects in this version? I converted my project in 2024.2, worked with that project, archived it, and then went to check the archive - toggled to restore it, but there was no archive. Just a folder for the project with no archive information. If I look at my hard drive where the archive lives, I see all the segments, so not sure why flame would not be seeing this information. I checked to make sure the permissions were all granted for flame.
SOLVED After several tests, I was able to download each segment separately via gdrive, though this created iterations to my segment. Therefore, instead of NY24-002_TEST_Archive_1.seg it was creating a segment that looked like this: NY24-002_TEST_Archive_1_002.seg, making the segments useless. For some reason, the added numerics were hidden, and I had to zip and unzip to reveal the sneaky archive destructo. I deleted the added numeric iterations, and that seemed to do the trick.
Do you have selected the archive tab in mediahub?
yup. toggling through archives via mediahub.
Do you see the header file on your filesystem? If so, then it’s a permissions thing.
If not, then somehow the header was deleted/moved.
The header is there. Everything looks right outside of flame.
Double check permissions
