Been doing this manually for years, but is there a way to lock key frame tangents together? So x, y, z of scale for instance? Would love not having to adjust each curve individually to match!
In the animation editor select the x channel then on the far right hit copy. Then select the y channel and in the far right hit link. Do the same for z.
Mike
I link two channels (whatever) with the third one. It’s so easy like copy-link and copy-link. Only one time and you can forget the problem.
Thanks guys. Much appreciated
I like the way that scale is linked by default in Nuke. Seems like we have to hit a lot of buttons in flame to get the behavior that is usually desired.
“But it’s always been like that.”
