No worries at all @knhn, and if I remember correctly I originally got it from @lewis or @ManChicken, or someone else, sorry I forgot ![]()
thanks @john-geehreng and @knhn . All fixed. Yesterday was not one of my best days. Update to 2025 was a big headtache ![]()
Hey @taylaner, that one is definitely on my list of things to get done. I’ll let you know as soon as I have a new version ready.
Hi
I’m new to python hooks.
my biggest problem is my IT dept.
I work for Warner Bros.
The idea of having my Flame connected to an outside server is a non starter.
Is there a way to download the Python scripts and install them in a secure location on my server?
many thanks in advance.
Hi @Rhiltzik
go to the Logik Portal and look for a link to the DropBox download page. it’s near the bottom of the page.
@MikeV Thanks for all your work on the Portal.
We’ve just upgraded to 2025 (from 2024) and I’m trying to make use of the new Centralised Components features, so amongst other things python scripts are stored at a shared network location and not at /opt/Autodesk/shared/python.
Is this possible and still use the Logik Portal?
I’ve downloaded the latest v6.2.0 and have tried two things:
- keep it in a containing “logik_portal_v6.2.0” folder and copy it to network location of other python scripts. Here it errors and tells me to re-install at /opt/Autodesk/shared/python/logik-portal
- remove it from containing “logik_portal_v6.2.0” folder (which I thought was the right thing to do, irrespective of the copy destination) and copy it to network location of other python scripts. Now it doesn’t appear in the Flame menu at all (but Flame can still see other python scripts at this location)
Afaik it’s not posssible to point the sysconfig.cfg for Centralised Components to two locations… so does this mean to see Logik Portal we need to keep all our python scripts with it locally as pre-2025?
Thanks
@cicero - if you point the centralized cfg to /opt/Autodesk/shared/python do things work?
this directory almost certainly gets created or re-used when flame is installed.
if you need the same scripts to be installed on every machine it’s only a couple of minutes to deploy that across a network.
otherwise mike has to rewrite all of his scripts to path to your special paths,
the path to some of his scripts is in the first few lines at the top of each script:
e.g.
# Main Script
SCRIPT_NAME = 'My Special Script'
SCRIPT_PATH = '/opt/Autodesk/shared/python/logik_python/Scripts/my_special_script'
VERSION = 'v2.0'
Yes they do, thanks.
I guess I was just asking for a sanity check, that having access to Portal means all python scripts need to stick with that sript locally, and can’t be centralised. That’s fine now that I know.
Hey @cicero
I haven’t had a chance to adapt the portal to work with the Centralized workflow yet. One thing you could try if you want to keep all the scripts in one location is to create a symlinked folder of the shared network folder where you want to keep all the scripts and then replace the /opt/Autodesk/shared/python folder with that symlinked folder.
Mike
Thanks Mike! And thanks for all you’re doing!
i guess this isnt planned at all? I was trying to make a centralized config for our studio to unify everything finally but i get the same error of course
I never quite understood why the script location was hardcoded but I’m sure there’s a good reason. Any script I’ve taken from the portal to use for us I’ve gone and changed the path manually as we have a centralized config.
For our own hooks we use the built-in method to get the location to then do whatever else we need it for.
script_path = os.path.abspath(os.path.dirname(__file__))
I’ve updated most of my scripts on the Logik Portal to use this now instead of having the path hard coded into the scripts. So they should be much more flexible now on where they can be installed to. For the Logik Portal I’m working on adding the ability to select where the scripts get installed too.
Mike
I just put out an updated version of the Logik Portal that will let you select the path where scripts get installed to. By default this is set to: /opt/Autodesk/shared/python. When changing this path, just make sure the path that gets set is a path Flame will be looking for the scripts in.
Mike
Just to say @MikeV, I just got round to updating our scripts and the Portal itself to a centralised location, which is going to help a lot with managing multiple suites etc.
All working well so far… Thanks again for the update, and for all your work!
Hi all,
First of all…Thank you so much for all of your time, effort, and energy on these scripts. We are so fortunate to have you in the Flame community!
I’ve installed them successfully on many machines in the past, but for some reason I’m having trouble getting the script installed on one machine. It appears to be successful in terminal, but then the Logik Portal is not shown as an option within Flame. This is on a Linux box running Rocky 9.5
Terminal output (which appears successful) below. Any thoughts? Maybe this is permissions related somewhere?
Many thanks!
Naveen
curl -s https://logik-portal.com/install.php?folder=logik_portal | bash
Logik Portal Python Installer
Installing script logik_portal to /opt/Autodesk/shared/python/logik_portal
Be sure to review any code and read the documentation before running it.
- LICENSE
- README.md
- Montserrat-Light.ttf
- Montserrat-Regular.ttf
- Montserrat-Thin.ttf
- CHANGELOG.md
- LICENSE
- README.md
- pyflame_lib_logik_portal.py
- logik_portal.py
Done.
logik_portal installed to /opt/Autodesk/shared/python/logik_portal
If Flame is running, refresh the python hooks to see the new script.
Enjoy!
Hey @naveen
What version of Flame are you running? Are there any errors in the terminal when starting Flame after installing the Logik Portal script?
Mike
Hi @MikeV ! Great questions. This system is running Flame 2025.2.5
In terminal I see:
Python encountered SyntaxError(“f-string: unmatched ‘(’”, (‘/opt/Autodesk/shared/python/logik_portal/logik_portal.py’, 1807, 78, " text_append=f’Download Complete\\n\\n{zip_path.rsplit(‘.’, 1)[0]}',\n", 1807, 79)) in unknown code
[PYTHON HOOK] An error occurred. Ignoring python hooks from /opt/Autodesk/shared/python/logik_portal/logik_portal.py
I just put a new version of the portal up on the site with a fix. That line of code had to be changed slightly to work in the version of python that Flame 2025.2 is using. Let me know how it goes with the new version.
Mike
