Updated Python Script
Uber Slate Maker vv2.6.1
- Reverted to older version of pyflame library for resolve
- compability issues that could cause script not to work.
Flame Sysconfig Setup
* Add Flame Sysconfig Setup app by @BayleyBY in Add Flame Sysconfig Setup app by BayleyBY · Pull Request #1 · flamelogik/flame-sysconfig-setup · GitHub * Fix release build: make build.sh executable by @BayleyBY in Logik.tv · GitHub…
Version: v1.0.0
Logik Backdoor v1.0.0
A bridge allowing other applications to control Flame using provided tools.
Mocha Flame Export
Mocha Flame Export v1.0.0 Send your work from Mocha Pro straight into a running Autodesk Flame or Flare session.
Version: v1.0.0
Sammie Roto Flame Export
Sammie Roto Flame Export v1.0.0 Send mattes exported from Sammie Roto straight into a running Autodesk Flame or Flare session, as soon as the export finishes.
Version: v1.0.0
* Update STATUS and CLAUDE.md after the v1.0.0 release by @BayleyBY in Update STATUS and CLAUDE.md after the v1.0.0 release by BayleyBY · Pull Request #9 · flamelogik/flame-sysconfig-setup · GitHub * Add screenshots to the README by @BayleyBY in fl (Florenz Kley) · GitHub…
Version: v1.0.1
Write File Transcoder v1.1.0
Connect Crypto v0.5
Creates and connects a Cryptomatte node to a read file node if it’s a cryptomatte.
Social Versions v0.3.3
Creates social timelines based on other, selected timelines.
Create Export Menus v5.6.0
LTX Alpha Gen OFX
- Faster processing on M1-family Macs.
Version: 0.1.5
LTX Upscale OFX
First public build of Upscale Native — SeedVR2 video upscale / restoration as a native Flame OFX plugin (no ComfyUI).
Version: 0.1
LTX Matte OFX
New in 0.4 - Input Colour menu (Auto / Display / Scene Linear / S-Log3 / ARRI LogC3 / LogC4).
Version: 0.4
* Update STATUS and CLAUDE.md after the v1.0.1 release by @BayleyBY in Update STATUS and CLAUDE.md after the v1.0.1 release by BayleyBY · Pull Request #14 · flamelogik/flame-sysconfig-setup · GitHub * Document one shared sysconfig.cfg for a mixed macOS and Linux faci…
Version: v1.1.0
LTX Alpha Gen OFX
- Missing mattes are shown, not passed through.
Version: 0.2
LTX Upscale OFX
Upscale Native 0.3 — Mac (Apple Silicon) and Linux (Rocky 8.10 / 9.x, Flame 2027).
Version: 0.3
LTX Matte OFX
Matte LTX Native 0.8 — Mac (Apple Silicon) and Linux (Rocky 8.10 / 9.x, Flame 2027).
Version: 0.8
Element Native OFX
First tester build of Element Native: generated stock elements (smoke, steam, dust, fog, rain, snow, embers, sparks, fire, birds, leaves, bubbles, or a prompt) with LTX-2.5, keyed off black and place…
Version: 0.2
Flame hooks hotfix OFX
For Matte LTX Native 0.8, Upscale Native 0.3, Depth Native 0.1 and Background Native 0.1 installs (Element Native 0.2 and later kits already include this).
Version: 1.1
Background Native OFX
Background Native 0.1 - first tester build.
Version: 0.1
Lens Blur Native OFX
Lens Blur Native 0.9 - Mac (Apple Silicon) and Linux kits.
Version: 0.9
Depth Native OFX
Depth Native 0.1 - first tester build.
Version: 0.1
Additive Key Native OFX
Additive Key Native 0.3 — Mac (Apple Silicon) and Linux (Rocky 8.10 / 9.x, Flame 2027).
Version: 0.3
Colour Match Native OFX
Colour Match Native 0.4 — Mac (Apple Silicon) and Linux (Rocky 8.10 / 9.x, Flame 2027).
Version: 0.4
Mocha Flame Export
Fixed buttons in Mocha Flame Export window.
Version: v1.0.1
Logik Portal v7.3.0
Face UV Native OFX
Shared engine brought up to date: installing this kit after one of the LTX kits (Matte LTX 0.9.2, HDR 0.2.2, Element 0.3.2, Background 0.2.2, Relight 0.1.1, Object Removal 0.1.1) no longer puts the o…
Version: 0.1.1
Motion Vectors Native OFX
Version: 0.1.1
Object Removal Native OFX
Gemma: the installer now brings the Gemma-4 12B text encoder (26 GB, from the same gated Lightricks/LTX-2.5 repository you accepted for Matte LTX; or point it at a copy you have) - this node sends LT…
Version: 0.1.1
Relight Native OFX
Version: 0.1.1
HDR Native OFX
Fixed: HDR stopped with ‘negative dimensions are not allowed’ after the first chunk on most clip lengths (anything other than 1-18 frames or 8k+1, e.g.
Version: 0.2.2
Sammie Roto Panda
A personal fork of Sammie-Roto 2 by Zarxrax, based on version 2.3.3.
Element Native OFX
Version: 0.3.2
Moving mode Gemma: the installer now brings the Gemma-4 12B text encoder (26 GB, from the same gated Lightricks/LTX-2.5 repository you accepted for Matte LTX; or point it at a copy you have) - this n…
Version: 0.2.2
Depth Native OFX
Version: 0.2.2
Shared engine brought up to date: when an engine folder is present, this installer copies the current engine_server.py into it, so installing it after one of the LTX kits no longer puts the old 'inst…
Version: 0.4.2
Upscale Native OFX
Version: 0.4.2
Matte LTX Native OFX
The engine log no longer tells you to install natten (NVIDIA-only: on a Mac it breaks every LTX render; on Linux it is pinned to a PyTorch/CUDA build that can replace the engine’s own).
Version: 0.9.2
- Node icon: the node now shows its Higgins Post tile in Flame’s node bin and schematic.
Version: 0.3.1
Version: 0.9.1
Denoise Native OFX
New: Denoise Native - motion-compensated video denoise, pure C++ inside Flame, no engine (about 1.2 s per 4K frame on an M2 Ultra).
Version: 0.1
Regrain Native OFX
New: Regrain Native - puts the plate’s grain back on a comp, like Flame’s Match Grain and Nuke’s DasGrain.
Version: 0.1
Face UV Native OFX
Shared engine brought up to date with Matte LTX Native 0.9.5 (Motion Detail) and Motion Vectors Native 0.1.4, so installing this kit after them does not roll the engine back.
Version: 0.1.4
Export Tracks also writes one Flame Stabilizer file with every point (_tracks.stabilizer, point 1 = Tracker1, point 2 = Tracker2 - Load it in Action Axis / 2D Transform / GMask; two points give rotat…
Version: 0.1.4
Version: 0.1.4
Relight Native OFX
Version: 0.1.4
HDR Native OFX
Version: 0.2.5
Element Native OFX
Version: 0.3.5
Version: 0.2.5
Depth Native OFX
Version: 0.2.5
Version: 0.4.5
Upscale Native OFX
Version: 0.4.5
Motion Detail (page Adjust & Render, Chunks): fixes matte drift and lost motion blur on fast motion.
Version: 0.9.5
LTX Alpha Gen OFX
- Frame Hold (new Motion column on the first tab).
Version: 0.2.1
Highlights only bloom where the picture is out of focus: the boost used to brighten in-focus highlights too.
Version: 0.9.4
The node icon now shows on macOS (it was installed readable by root only); the Mac installer now makes the installed plugin readable.
Version: 0.3.2
Face UV Native OFX
Shared engine updated: faster (stored frames read and written in parallel, colour conversions and Depth Stabilize on the GPU, HDR finish on the GPU, Motion Vectors check views), DA3 Metric depth in r…
Version: 0.1.5
Version: 0.1.5
Version: 0.1.5
Relight Native OFX
Version: 0.1.5
HDR Native OFX
Version: 0.2.6
Element Native OFX
Version: 0.3.6
Version: 0.2.6
Depth Native OFX
Output: Raw Depth (metres with DA3 Metric) for Lens Blur Native’s Physical Camera.
Version: 0.2.6
Working Space (S-Log3 / LogC3 / LogC4 / ACEScct): the add is done in linear.
Version: 0.5
Version: 0.4.6
Physical Camera mode: a metric Z (Depth Native > DA3 Metric > Output: Raw Depth) becomes a real lens - Camera tab with sensor presets, focal length, f-stop, focus distance in metres, Analyze Camera (…
Version: 0.9.6
Upscale Native OFX
Version: 0.4.6
Version: 0.9.6
Regrain Native OFX
Regrain Native 0.2 - now on the GPU: Metal on the Mac, Vulkan on Linux.
Version: 0.2
Denoise Native OFX
Denoise Native 0.2 - now on the GPU: Metal on the Mac, Vulkan on Linux.
Version: 0.2
UV Wrap Native 0.1.1 - wrap a UV-space texture back through a UV pass and comp it OFX
New node.
Version: 0.1.1
Face UV Native OFX
Adjust tab: Show Mesh draws the tracked mesh in the viewer (Mesh Opacity).
Version: 0.2
Method: Distribution (3D) and Distribution + Tone - the Front’s whole colour distribution is moved onto the Reference’s (iterative distribution transfer into a smoothed 33^3 grid, falling back to the…
Version: 0.5
Denoise Native OFX
Analyze Noise: resizable Sample Box, Auto Box placed and rated on the current frame (POOR / OK / GOOD), Analyze Frames from one frame, a few, or keyframed along the shot, Calibrate to the sensor’s no…
Version: 0.3
Regrain Native OFX
Grain Profile input (blue matte socket) for Denoise Native 0.3’s matte output (Matte Output = Grain profile): Analyze takes the measured noise curves from it - Original and Degrained are still needed…
Version: 0.3
Paint Carry: Off-Frame Paint = Inpaint (default) / Fade out / Clamp - where the carried frame has left the picture the paint is filled from its neighbours instead of streaking from the edge (the engi…
Version: 0.1.7
Status reads ‘Refresh Status to check - it refreshes itself when done’ while a job runs, and the Flame auto-refresh hook makes at most two refresh passes per finished job (20 s apart), so it no longe…
Version: 0.1.7
Relight Native OFX
Version: 0.1.7
HDR Native OFX
Version: 0.2.8
Element Native OFX
Motion group: Wind Direction + Wind Strength, Turbulence, Vortex, Density, Speed, Detail Scale, Lighting - they write the description for the model (the preset’s own motion is dropped once wind or sp…
Version: 0.4
The aifx auto-refresh hook makes at most two refresh passes per finished job, 20 s apart, then stops - the earlier hook kept re-checking and reset the Media Panel selection every few seconds while a…
Version: 1.2
Version: 0.2.8
Depth Native OFX
Version: 0.2.8
Working Space: Auto (from Flame’s clip tag, 2026.1+) and Scene Linear added to the log curves.
Version: 0.7
Input Colour (page 1): Auto from Flame’s clip tag (2026.1+), S-Log3, LogC3, LogC4, ACEScct or Scene Linear - the defocus is computed in linear light so highlights bloom into proper bokeh on a log pla…
Version: 0.9.8
Upscale Native OFX
Version: 0.4.8
Version: 0.9.8
Continue Folder
Face UV Native OFX
Unwrap Margin ran the wrong way in the Texture wrap (the painted texture landed smaller than the unwrap it was painted on); it now matches the Unwrap output and UV Wrap Native.
Version: 0.2.1
Paint Carry: the matte output is the carried paint’s own matte again (the paint’s alpha carried through the motion, faded by confidence when the gate is on).
Version: 0.1.8
Engine: pressing the node’s button again while its run is still going (Overwrite This Version, or Delete Result then the button) now stops that run and starts the new one - before, the old run carrie…
Version: 0.1.8
Light-Limited Matte (Spill Difference): the matte’s add is capped by how much light the Front actually has next to the screen, and a black floor keeps the comp from dropping below the darker of Front…
Version: 0.7.1
Upscale Native OFX
Version: 0.4.9
Iris > Preset: 17 named lenses after the generic looks - Cooke S4, Cooke Speed Panchro, Zeiss Super Speed, Zeiss Master Prime, Zeiss Ultra Prime, Canon K-35, Leica Summilux-C, Panavision Primo, Panav…
Version: 0.9.9
Output = Unwrap (picture in UV space): the other direction - the picture on Back (or Front) flattened into UV space through any UV pass (Face UV Native, a Maya UV render, another tracker), the UV squ…
Version: 0.3
