Logik Portal Updates
Updated Python Scripts
Reveal Path v2.12.0
  • Reveal in Finder now selects the source file in the Finder window. Image sequences select the first frame.
  • Audio clips and audio segments can now be revealed in Finder and MediaHub.
  • MediaHub files with 4 or 5 letter extensions (.aiff, .flac, .tiff, …) can now be revealed.
  • Removed duplicate ‘Reveal Shot Folder in Finder’ Batch menu entry.
  • Fixed Bug: PyFlameLib used QScreen.screenGeometry(), which doesn’t exist in PySide6. Now uses QScreen.geometry().
    View on Logik Portal
Version Upper v3.0.1
  • Dialogs show the normal cursor instead of Flame’s wait cursor, the fish.
Updated Tools
Denoise Native OFX
    The noise profile’s sensor curve is fitted as a real sensor model (read + shot + PRNU, no negative terms) in linear light: whole-frame profiles on S-Log3 / LogC plates could come out U-shaped and und…
    Version: 0.3.1
UV Wrap Native 0.1.1 - wrap a UV-space texture back through a UV pass and comp it OFX
    Unwrap: cells that straddle a UV discontinuity (the nose silhouette in a 3/4 view, the jaw line, an ear) were painted as a stretched band across the far side of the square - the mirroring around the…
    Version: 0.3.1
Face UV Native OFX
    The refine pass (TAPIR) needs the python package dm-tree; when it is missing the track now finishes without the refine and says so in the status (it used to fail with “No module named ‘tree’”).
    Version: 0.2.2
Motion Vectors Native OFX
    Export GMask: Keyframes On - Shape vertices (as before), Axis (position / rotation / scale fitted to the tracked vertices every frame and keyed on the GMask’s axis, the shape itself static - parent a…
    Version: 0.1.9
Object Removal Native OFX
    Qwen / Flux fills: the removal prompt no longer names what must not appear (image-edit models tend to paint what they are told not to), and after each fill SAM3 checks the hole - if a person was inve…
    Version: 0.1.9
Relight Native OFX
    Engine memory: Diagnostics has a Free Engine Memory button that drops every model the engine is holding so the RAM goes back to Flame (the next job loads what it needs again), and the aifx_release_me…
    Version: 0.1.8
HDR Native OFX
    Version: 0.2.9
Element Native OFX
    Version: 0.4.1
Background Native OFX
    Version: 0.2.9
Depth Native OFX
    Version: 0.2.9
Upscale Native OFX
    Version: 0.5.0
Matte LTX Native OFX
    Version: 0.9.9
Add Audio v1.5.1
  • Audio tracks are now labelled after the audio added to them: Stereo L/R, or 5.1 LF, RF, C, LFE, LS, RS and 5.1 Stereo L/R. The audio clips keep their original names.
  • 5.1 audio now stops with an error naming any missing, duplicate or misnamed channel files. Previously a misnamed file was silently skipped and the other channels shifted tracks.
  • Selection order is now checked before anything is created. Selecting audio before its sequence shows an error instead of failing and leaving a partly made library.
  • Added note that the script only works with sequences.
  • Updated to PyFlameLib v5.5.3 - Fixes screenGeometry error with Flame 2027.2.
  • Changed license from GPL-3.0 to MIT. See LICENSE file for details.
Add Dated And Timed Folders v2.8.0
  • In the MediaHub if no folder is selected, new dated/timed folders can be created at whatever path the MediaHub is currently open to.
  • Setup now only accepts date formats the script can use: YY or YYYY, MM and DD once each, separated by - / . or nothing. Other characters show a message listing them. A bad saved format no longer stops Setup from opening.
  • Selecting a library or folder together with other items no longer fails. Only the libraries and folders are used.
  • MediaHub folders are now always created inside the selected folder.
  • With several libraries or folders selected, folders are created in each one that needs them. The ones that already have them are listed in one message.
  • MediaHub folders that can’t be created are now shown in a message with the reason.
  • The script now stops cleanly if the install check fails.
Add Gmask v2.10.1
  • Add GMask menu now only shows when nothing is selected or a single node with a Matte input is selected.
  • Fixed GMask connecting to the Back Matte input instead of Matte on Comp nodes.
Add Mux v2.7.1
  • Freeze Selected MUX now skips non-MUX nodes in the selection instead of failing.
Axis To Point Locators v1.6.1
Color Segment FX v1.5.1
  • Fixed Apply Color stopping partway when a segment can’t be read.
  • Fixed error when items other than sequences are selected along with a sequence.
  • Added Clear All Color button. Clears color from all colored segments in the selected sequences.
  • Fixed No Color and Clear All Color not clearing colors set in Flame.
Create Export Menus v5.6.1
  • Updated to PyFlameLib v5.5.3.
Create Projection v2.11.1
Create Shot Folders v5.5.1
Csv Renamer v1.0.1
Delete Empty Folders v1.7.0
  • Fixed Flame hanging when an empty folder can’t be deleted. Folders that can’t be deleted are listed in one message.
  • Fixed error when clips are selected along with libraries or folders.
  • Folders are now deleted without a confirmation prompt for each folder.
Delete Folders v2.11.1
  • Confirmation window now lists the folders to be deleted.
  • Added a second warning when a selected folder is a symlink. Confirming deletes the folder the link points to and removes the link.
  • A folder that fails to delete no longer stops the rest. Failures are listed in one message at the end.
  • Symlinks pointing to /, a drive root, the home folder or a folder containing the link are never deleted.
Delete Iterations v1.7.1
Encompass Selected Nodes v2.9.1
Fill Gaps v1.5.1
Flush Renders v1.4.1
Folders To File System v1.7.0
  • Fixed wrong folder paths when the selected folder’s name is part of a parent, library, workspace or project name.
  • Fixed permission error message not showing the selected path.
  • Errors creating folders are now shown instead of being hidden.
Import Browser v2.7.1
Import Camera v4.17.1
Import ST Map v3.2.1
Import Write Node v2.12.1
Invert Axis v2.11.1
Logik Backdoor v1.0.1
Multi Batch Render v4.15.1
Neat Freak v2.3.0
  • Fixed Neat v5 not being used when Neat v6 isn’t installed.
  • Fixed error when Neat isn’t installed. One message is shown and no empty nodes are left.
  • Fixed saved profiles that fail to load leaving empty Neat nodes.
  • Fixed error when the profile folder has no profiles, and profile names with dots.
  • Fixed timeline segments being skipped after one fails. Failed segments are listed at the end.
  • Fixed error when non-clip items are selected along with clips.
  • Save Neat Node Profile now saves the selected Neat node, checks the name, and asks before replacing a profile.
  • Fixed error when the script install check fails.
  • Added Neat Denoise Selected Clips with Profile menu option to Batch, Media Panel and Timeline.
  • Removed Use Saved Profiles option from Setup. Neat Denoise Selected Clips now always uses default Neat settings.
PDF to JPG v1.1.0
  • Now works in linux.
Refresh Python Hooks v1.9.1
Rename Shots v1.13.1
Replace Render Nodes v2.3.1
Set In And Out Plus One Frame v1.4.1
Updated Tools
Camera Track Native 0.2 - 3D camera tracker, Mac OFX
    Setup file: Flame menu Python > Higgins Post > Setup…
    Version: 0.2.2
Face UV Native OFX
    Version: 0.2.4
    Version: 0.2.1
    Version: 0.2.1
Relight Native OFX
    Version: 0.1.10
HDR Native OFX
    Version: 0.3.1
Element Native OFX
    Version: 0.4.3
    Version: 0.3.1
Depth Native OFX
    Version: 0.3.1
Upscale Native OFX
    Version: 0.5.2
    Version: 0.9.11
Lens Blur Native OFX
    Inpaint Behind Matte (Focus & Inpaint tab): with a Front matte (or a Z nearer than Inpaint Split) and no Background connected, the plate behind the matted element is filled in before the defocus - Pu…
    Version: 0.9.10
New Tool
Matte Refine OFX
    Three OFX plugins for Autodesk Flame that refine an existing matte.
    Version: v0.4.0
Updated Tools
Camera Track Native OFX
    Engine synced for the 26 Oct batch (Render Monitor + optional cloud rendering ride in the shared engine - see the Matte LTX Native 0.9.12 notes).
    Version: 0.2.3
Face UV Native OFX
    Render Monitor: a Flame-style progress window (Rendering …
    Version: 0.2.5
    Version: 0.2.2
    Version: 0.2.2
Relight Native OFX
    Version: 0.1.11
HDR Native OFX
    Version: 0.3.2
Element Native OFX
    Version: 0.4.4
Flame hooks hotfix OFX
    For kits older than 26 Oct 2026: installs the current Higgins Post Flame hooks (auto-refresh, context, Free Engine Memory, Setup dialog with the optional cloud backend, Render Monitor).
    Version: 1.3
    Version: 0.3.2
Depth Native OFX
    Version: 0.3.2
Upscale Native OFX
    Version: 0.5.3
    Version: 0.9.12
Write File Transcoder v1.2.0
  • Added excluded folders: renders under a folder listed in Settings, General tab (e.g. /Volumes/Video) never start a review automatically. Whole folders are matched, so /Volumes/Video does not exclude /Volumes/Video2. Right-click → Create review… still works anywhere.
New Tools
Optics Native 0.1 - glow, glare, halation, light wrap, glints OFX
    First tester build.
    Version: 0.1
Screen Comp Native 0.1 - screen replacement with display models OFX
    First tester build.
    Version: 0.1
Updated Tools
    - First Linux kit (the Mac kit continues).
    Version: 0.3
UV Wrap Native OFX
    - The erode / dilate passes sweep rows over bands of columns instead of walking columns: the vertical passes no longer stride the whole image and go parallel (also in Face UV Native and Camera Track…
    Version: 0.3.2
Denoise Native OFX
    - Hair, fabric and fine texture: Normal quality is now two stages of grouped 8x8 block filtering on the luma (a hard threshold pilot, then an empirical Wiener on the same groups) instead of an isotro…
    Version: 0.4
Face UV Native OFX
    - Where each node renders: Python > Higgins Post > Setup…
    Version: 0.2.6
    Version: 0.2.3
    Version: 0.2.3
Relight Native OFX
    Version: 0.1.12
HDR Native OFX
    Version: 0.3.3
Element Native OFX
    Version: 0.4.5
    For kits older than 30 Oct 2026: installs the current Higgins Post Flame hooks (auto-refresh with the Flame 2027.2 doPreventiveLock crash fix, context hook with lens metadata, Free Engine Memory, Set…
    Version: 1.4
    Version: 0.3.3
Depth Native OFX
    Version: 0.3.3
    - Iris presets: the named lenses’ blade counts, roundness and squeeze now come from published specs, the same values as Optics Native (Cooke S4/i 8 leaves, Zeiss Master Prime 9 and round at every sto…
    Version: 0.9.11
Upscale Native OFX
    Version: 0.5.4
    Version: 0.9.13
Updated Tools
    - Fix: Flame could quit (“Assertion failed: (m_inputLocks.size() == 0), function doPreventiveLock”) when a solve finished.
    Version: 0.3.3
Denoise Native OFX
    - Analyze Motion (new, Temporal group): one press measures per-pixel motion for the whole clip (SEA-RAFT, through the Higgins Post engine) and stores it with the node; the neighbour frames are then l…
    Version: 0.4.3
Regrain Native OFX
    - The Grain Profile input reads the Denoise node’s matte at any bit depth: 8, 10 and 12-bit batches as well as 16 / 32-bit float - no batch conversion needed.
    Version: 0.4.1
Face UV Native OFX
    - Engine sync with Denoise Native 0.4.3 (one shared engine): a motion job for Denoise’s Analyze Motion (the forward vectors only - no backward pass, ST map or check views) and jobs no node refreshes…
    Version: 0.2.8
    Version: 0.2.5
    Version: 0.2.5
Relight Native OFX
    Version: 0.1.14
HDR Native OFX
    Version: 0.3.5
Element Native OFX
    Version: 0.4.7
    Version: 0.3.5
Depth Native OFX
    Version: 0.3.5
Colour Match Native OFX
    Version: 0.6.1
Upscale Native OFX
    Version: 0.5.6
    Version: 0.9.15
    - Fixed: Match Lens during a render could crash (it held pointers to the render’s images); a parameter / pool race between renders; black (not garbage) when an input can’t be read.
    Version: 0.1.1
    - Fixed: dragging the corners after Load Corners; the GPU switch is read per render; an unreadable Front; point-track bounds; a degenerate projection on the Metal path.
    Version: 0.1.1
Pixel Spread Native OFX
    - GPU = CPU: Texture (PatchMatch) on the CPU now follows the GPU’s scheme exactly, and a GPU bug that left stale values in the match field outside the hole (fills up to 1.0 off) is fixed; the Metal p…
    Version: 0.4.1
UV Wrap Native OFX
    - Fixed: an edge ring in the corner texel’s colour; the screen-space hold frame outside the track; motion blur now interpolates the mesh; stale caches after an input change; the output size follows t…
    Version: 0.3.3
    NEW IN 1.5 - Python > Higgins Post > Check for Updates…
    Version: 1.5
Additive Key Native OFX
    - Fixed: an unreadable Front left the output unwritten; the Beyond sizes scale with the render scale (proxy); regions use the full frame bounds.
    Version: 0.7.2
    - Lens Model page (new): Model = Ray-Traced Lens.
    Version: 0.9.12
Batch Nodes v3.13.0
  • Create Menu for Selected Node now stops with an error if the node name contains a quote or slash.
  • Adding a menu from the Setup window now asks before overwriting an existing menu, and removes the old saved setup folder when a saved-setup menu is replaced.
  • Remove now deletes only the selected menus’ own files and setup folders, not other menus whose names contain them, and asks for confirmation first.
  • Renaming a menu to the name of another existing menu now asks before replacing it. Names with slashes, backslashes or quotes are rejected before anything changes, and if the rename still fails partway the changes are undone.
  • Renaming a menu now only changes the menu name in the menu script, not matching text in its code or path.
  • Create Menu for Selected Node now asks before overwriting an existing menu that has no saved setup folder.
  • Setup window now opens when the Matchbox shaders folder for the current Flame version is missing.
  • Script now stops cleanly if the install check fails.
Clip To Batch Group v3.0.1
Create Media Panel Templates v3.10.0
  • A / in the template name is now replaced with an underscore in the menu file name.
  • Generated folder templates now skip selected clips when run.
  • The overwrite warning now names the existing template when a different name uses the same menu file name.
  • Overwriting a template now names the template that will be replaced, and the old template is only removed after the new one is written.
  • Fixed template names with an apostrophe or quote creating a menu with a syntax error.
  • Fixed empty folders being left out when several items are selected.
  • Fixed wrong template tree when the selected item’s name is part of a parent, library or workspace name.
  • Clips in the selection are now ignored instead of stopping the script.
  • Fixed template names with a backslash causing an error or a wrong menu name.
  • An empty template name now shows an error instead of creating a hidden menu file.
  • Fixed library templates creating their libraries once for each selected item.
Master Builder v1.8.0
  • Updated docstring: where masters are saved, how they are named and what happens if a build fails.
  • Fixed builds failing in Flame 2027 (primary_track error).
  • Fixed error when Reel Group has no clips or sequences. An error message is now shown.
  • Fixed reels with different numbers of clips passing the clip count check when no reel has a single clip.
  • Fixed error when another item is selected along with the Reel Group.
  • If a build fails, an error message is now shown and Temp Reel is removed. Master Reel is removed if it holds no masters.
Nano Banana v1.3.0
  • Working path is now shown under the image gallery.
  • Added a Change Path button to change the working folder from the main UI.
  • Fixed: in Flame 2027.2 every request failed with “No internet connection” because Flame’s Python couldn’t find its SSL certificates. Requests now also use the certificates that come with Flame’s Python (certifi) and the system’s own certificate bundle, so nothing needs to be installed.
  • Fixed: Send Prompt and Gemini Chat caused an error when the prompt image file was moved or deleted outside the script. The error names the file, the prompt image is cleared and nothing is sent.
  • Added the 512 (512px) resolution for Nano Banana 2.
  • Added Gemini Nano Banana 2.1 (Nano Banana 2.1) and made it the default model.
  • Added Thinking Level menu.
  • Updated Gemini Chat to use Gemini 3.8 Flash. Gemini 3.7 Flash is deprecated and Google auto-routes it to 3.8 (no shutdown date).
  • Fixed: the image gallery listed file types the prompt image can’t show (exr, dpx, tif…), and clicking one raised an error. The gallery now shows only PNG and JPEG files, so Import to Flame only gets files Flame can read.
  • Fixed: the prompt image was sent with the wrong type for non-PNG files. The type now matches the file (PNG or JPEG).
  • Fixed: Send Prompt and Gemini Chat stayed enabled during a request, so a double click could send a second paid request. Both are disabled (and Return does nothing) until the request ends.
  • Fixed: saved resolution and aspect ratio were lost when the window opened (4K/4:3 came back as 1K/1:1). Changing the model now resets them to that model’s first options.
  • Fixed: clicking Done saved the resolved images path over the tokenized one, so every project saved into the first project’s folder.
  • Fixed: Send Prompt API errors now show Google’s error message.
  • Requests over Google’s 20 MB request size limit are no longer sent. An error shows the prompt image size.
  • Fixed: running the script again on the same clip opened a file exists dialog and the window didn’t open. The exported frame is now overwritten.
  • Export errors are now shown in a message window.
  • Fixed: exporting failed when the images folder didn’t exist yet. The folder is now created.
  • Fixed: every selected clip was exported. Only the first selected clip or sequence is exported now.
  • Fixed: an empty Gemini Chat reply was added to the history instead of showing an error.
  • Fixed: “Image generated successfully.” was shown when no image came back. The reason is now shown (blocked prompt, safety finish reason, returned text).
  • Fixed: “Please wait…” stayed in the status line after an empty prompt or a failed request.
  • Fixed: an empty or invalid API response raised an error instead of showing a message.
  • Fixed: Delete Image raised an error when the selected file was already removed.
  • Fixed: Reveal in Finder/MediaHub failed when the images folder didn’t exist yet. The folder is now created.
  • Fixed: Return pressed in the image gallery sent a prompt. Return/Enter in the prompt text field now sends the prompt, Shift+Return adds a new line, and Return elsewhere no longer sends.
Uber Slate Maker v2.7.0
  • Fixed spaces around CSV column headers or RATIO values causing errors, skipped rows or tokens left in the slate text. Also fixed in the Slate Name token menu.
  • Fixed blank or short CSV rows causing an error.
  • Fixed CSV files saved as CSV UTF-8 (Excel) not reading the first column header.
  • Fixed Create Slates making extra or wrong slates after a Slate Preview or a failed run.
  • If Create Slates, Update Slates or Rename from Slate fails, an error message is now shown. Create Slates shows its window again so the CSV can be fixed. Before, the window was left hidden.
  • An empty -= Slates =- library is no longer created when there are no slates to create.
  • Fixed Enter key error in the CSV Editor.
  • Escape now closes the script windows.
Updated Tools
    - Paint hand-over (more than one paint frame - Paint Frame 2 / 3): the next paint no longer pops on at the switch.
    Version: 0.3.4
    - A black matte now means nothing to match: when the Reference’s alpha (or the Front’s matte) is black on the frames being measured, the Front passes through untouched - it used to be matched against…
    Version: 0.6.2
New Python Script
Create New Folder v1.0.0
    Adds a pop-up entry field for naming new folders created in the MediaHub Files tab.
Batch Group To Shot Folders v1.1.0
  • Fixed Replace deleting a selected batch group when a same-named batch group in the selection is processed first. Batch groups in the selection are never deleted.
  • Fixed Replace deleting a batch group that is already in its destination folder. Batch groups already in their destination folder are now skipped.
Fix Premiere XMLs v3.5.8
    Fix and/or Resize Adobe Premiere XML’s.
Shot Sheet Maker v3.15.0
  • Added Sort By. Shots can be listed by Shot Name (alphanumerically) or in Edit Order (timeline order, the default).
  • An overwrite warning now lists any shot sheets or images folders that already exist in the export path. Cancel writes nothing and keeps the window open.
  • Items that aren’t sequences, such as folders, are now skipped. Before, a sequence selected with a folder stopped the script.
  • Text starting with = is now written as text, not as a formula.
  • Every column named after the same clip info item is now filled. Before, only the first one was.
  • Every shot now gets its own row. Before, shots with the same name were merged into one row. Saved images of shots with the same name get _2, _3, … added.
  • Shot names with characters such as & or < no longer stop the export.
  • Sequence names that aren’t allowed as Excel sheet names (too long, with : * ? / or a backslash, or starting or ending with ') are now shortened or changed instead of stopping the export.
  • Sequence names that differ only in upper and lower case no longer stop the export or overwrite each other’s workbook.
  • In workbook and images folder names, / : and backslash from the sequence name are replaced with _. Unsafe characters in saved image names are replaced with _.
  • If the export fails, an error is now shown and the window opens again. Before, the window closed with no message.
  • Added Images in Cells. When on, thumbnails are placed inside their cells (Excel 365, Excel 2024 and Excel for the web).
  • Updated the bundled xlsxwriter to 3.2.9. Older installs are updated the next time the script opens (the system password is asked for once).
  • Floating thumbnails now use xlsxwriter’s own move and size with cells setting, so the workbook is no longer unzipped and rezipped after it is written. A temp_xlsx folder in the export path is no longer deleted.
  • Fixed Clip Info showing the wrong values for Shot Length, Source Length and Comment.
  • Shot Frame In and Shot Frame Out are now added to Clip Info.
  • The Clip Info column is now created when only Shot Frame In, Shot Frame Out or Comment is selected.
Uber Save v5.2.0
  • Save Selected / Iterate and Save Selected now work on batch groups in libraries and folders: each one is moved to the Desktop, saved, and moved back, one at a time in selection order.
  • A save path with a token that resolves to nothing (such as an empty project nickname) or a token that can’t be resolved is now reported as an error instead of saving to the wrong folder or creating a folder named after the token.
  • The Setup window can’t be used while the New / Edit / Duplicate path window is open.
  • Duplicating a duplicated path no longer stacks the names. Duplicates are named Copy, Copy 2, Copy 3 and so on.
  • Browse in the New / Edit / Duplicate path window now starts at the path being edited.
  • Items in the selection that aren’t batch groups are now skipped with a warning in the console. Before, folders named after the path tokens were created for them and the save failed with a misleading error.
  • Saving a path with the name of another saved path now shows an error instead of replacing that path. Spaces at the start and end of path names and paths are removed.
  • Fixed a failed save being reported as saved. A save folder that can’t be written to is now reported before the batch group is iterated, and a batch setup that isn’t saved is reported as an error.
  • Delete in Setup now asks for confirmation, and no longer selects and saves another path when the selected path is deleted. No path is selected until one is chosen and saved.
  • A saved path is now selected when no path is selected, so saving works without clicking Save in Setup.
User Batch Setups v1.10.0
  • Fixed the menu paths in the setup path error message and in the Menus section of this docstring. They now match the real menu: Logik → Logik Portal Script Setup.
  • Fixed one unreadable batch setup stopping the menu refresh and removing the other menus. Unreadable setups are now skipped and listed in one message. If no setup can be read, the menus are left as they were.
  • Fixed two setups with the same name (for example comp.batch and comp.flare.batch) writing to the same menu. The first is kept and the other is skipped.
  • Fixed messages popping up at every Flame startup when the setups folder is missing or has no setups. These are now only printed to the console at startup.
Updated Tools
    NEW IN 1.6 - Flame no longer slows down with the hooks installed, and the Batch / Media Panel highlight no longer jumps to the batch name.
    Version: 1.6
    - Engine sync (one shared engine) - nothing else changes in this node: Cloud rendering (Runpod Serverless): a finished job could be reported as failed and its result lost - the worker copied the resu…
    Version: 0.3.5
Face UV Native OFX
    Version: 0.2.9
    - Paint Carry Transparency (new, under Motion Blur): 0-100 as Flame’s Transparency - 0 = the carried paint fully shown, 100 = gone.
    Version: 0.2.6
    - Edit Prompt…
    Version: 0.2.6
Relight Native OFX
    - Edit Prompt…
    Version: 0.1.15
HDR Native OFX
    Version: 0.3.6
Element Native OFX
    - Edit Prompt…
    Version: 0.4.8
    - Edit Prompt…
    Version: 0.3.6
Depth Native OFX
    Version: 0.3.6
    Version: 0.6.3
Upscale Native OFX
    Version: 0.5.7
    Version: 0.9.16
CMYK to RGB v1.1.0
  • Added Linux support.
  • Intel Macs are not supported. A message is now shown instead of installing a package that can’t run.
  • Fixed the Pillow install reporting success when it failed.
  • The Python version is now read from Flame’s Python (3.11 or 3.13) instead of guessed from the Flame version.
  • Images without an embedded CMYK profile are now converted with the U.S. Web Coated (SWOP) v2 profile. Before, they got a basic conversion with wrong colors.
  • Fixed black point compensation not being applied.
  • One failed image no longer stops the rest. A single summary is shown at the end instead of a message for each image.
  • Fixed errors when other items are selected along with the images.
  • Only CMYK images are converted. RGB, grayscale, LAB and other images are skipped.
  • PSDs with extra channels (alpha or spot) are now refused. Before, they were saved with scrambled pixels.
  • Image sequences and missing files are now skipped.
  • Output images now include an sRGB profile and keep their DPI. JPEGs are saved without chroma subsampling.
  • A warning is now shown before existing files are overwritten.
  • Two selected images that would save to the same file name (for example image.psd and image.tif) are no longer both saved.
  • The menu now only shows for supported image files.
Create Shot Folders v5.5.2
  • Minimum Flame version is now 2025.2.
  • Fixed <SeqName> and <SEQNAME> resolving to nothing in the file system path when the shot name pattern uses a shot list or range, such as PYT_<ShotNum[0010, 0020]> or PYT_[0010-0050]. Shot folders were created one level too high.
  • Fixed copying clips into the plate folder failing when the plate folder has subfolders of its own.
Import Write Node v2.12.2
  • Fixed open clips not being found when the Write File node’s Create Open Clip name uses <batch iteration> or <version name>. The batch iteration name was used with quote marks around it.
Multi Batch Render v4.15.2
  • Fixed Render/Write nodes being replaced in the batch group shown in Batch instead of the one being rendered. Each batch group is now shown in Batch before its nodes are replaced and it is rendered.
  • Fixed an error at the end of Render Selected Batch Groups (Media Panel).
New Tool
Ignite
    First release of Ignite, a small launcher for Autodesk Flame and Flare on macOS and Linux.
    Version: v1.0.0
Updated Tool
Higgins Post OFX
    Background 0.3.7 → 0.3.8, Camera Track 0.3.6 → 0.3.7, Depth 0.3.7 → 0.3.8, Element 0.4.9 → 0.4.10, Face UV 0.3.1 → 0.3.2, Flame Hooks Hotfix 1.9 → 1.10, HDR 0.3.7 → 0.3.8, Matte LTX 0.9.17 → 0.9.18,…
Import Camera v4.17.2
  • Fixed Use Tokenized Path: the script called pyflame.resolve_path_tokens, which no longer exists in PyFlameLib. It now uses pyflame.resolve_tokens.
Updated Tool
Higgins Post OFX
    Screen Comp 0.1.1 → 0.1.2
New Python Script
Create Project Folders v2.0.0
    Creates a project file system folder structure and/or media panel library/folder structure when Flame starts and when a project is loaded.
Fix In Between Frames v1.0.2
  • Fixed: screenGeometry error with Flame 2027.2.
New Python Script
Muxed Elbows v1.0.0
    Convert Mux nodes to Elbow nodes, or Elbow nodes to Mux nodes, keeping all connections.
Nano Banana v1.4.0
  • The images folder and the Change Path button are now at the top of the Image Gallery.
  • The images path is no longer in the Setup window. Set it with the Change Path button in the main window.
  • The path selection window (Change Path) now stays on top of the main window.
  • API key error messages from the Setup window’s Save now open on top of the Setup window.
  • The prompt image info now also shows the image’s aspect ratio (Ratio: 16:9). A ~ means it’s close to that ratio, not exact.
Do you have an agent doing these posts for you, or has keeping up with the velocity of vibe-codedf Portal updates become a part-time job? There’s a new wall of text from you daily!
Haha more of a bot than an agent. At the end of every day it checks for anything new people have submitted to the Logik Portal site and posts the description of it here. Unfortunately last night the bot had a bit of a brain fart and posted about things that were already previously mentioned which is why it was so long lol. It was really just one thing that should have been listed. But there are also a lot more really awesome things being contributed by people which is awesome to see!
Updated Tool
Matte Refine OFX
    This release adds one feature to Matte Refine ML.
    Version: v0.5.0
Updated Tool
LTX Alpha Gen OFX
    LTX Alpha Gen 1.0.1 (v1.0.1) - Linux: LTXAlphaGen-1.0.1-rocky9.tar.gz.
    Version: 1.0.1
