Logik Portal
Hey Kyle
That’s a good idea. I can look into setting up something possibly on pyflame.com. Or even better on this site if the guys @andymilkis @randy think it’s possible to setup a simple submit page. In the meantime feel free to email me any scripts you’d like to have on the Portal and I can get them on there for you.
Mike
I think I understand the challenge, and want to help, but not sure how. We’re a Squarespace hosted side with a subdomain managed by an offiicially hosted Discourse… @kyleobley, would a web based submission tool work? I’m not sure how we can do that but if we can we will.
In the interest of not having things too fragmented, being able to upload scripts to pyflame.com would be ideal. That way the majority of hooks live in one place and people are more likely to find them.
@MikeV I’ll email you them today once I add the header/info bits.
For anyone uploading python scripts to the Logik Portal, I’ve just posted a new version of the Portal which should make uploading scripts easier. You can now enter all the script info in the script submit window instead of needing to have it in a comment section in the script. Hopefully it will make submitting a script a little easier.
Mike
Nice! Thanks, Mike!
Yet another update for the Portal. Thanks to @digitalbanshee for reporting a problem with the matchbox install. That’s now fixed.
Hey hey @mikev, I’m using the portal and trying to install Matchbox on 2021.2.1 and it doesn’t seem to be working, even thought it says it is. Thoughts?
What version of the portal are you using? 1.4 is the latest which had a fix to the matchbox tab.
1.4.
Are there any errors in the shell? What path are you sending the matchboxes to?
No errors in shell that I can see…
PYTHON : flameTimewarpML cleaning up
LOG : Uninitialising.
MULTI-PROCS : Uninitialising.
Stopping managed threads.
FLEX : Uninitialising.
Warning: QCoreApplication::postEvent: Unexpected null receiver
Unregistering TexPoolMgr30 from resource manager
Uninitializing Python interpreter
Executing command: /bin/sh /usr/sbin/system_profiler SPPCIDataType -xml > /var/tmp/tmp72
Uninitialisation complete.
Batch pipeline logger initialising.
Disconnecting socket [fd:63]
[VREF]: checks canceled (1 queued)
[VREF]: shutdown completed
randymcentee@dxs-flame-01 ~ % flame
Parsing ‘/opt/Autodesk/cfg/env.cfg’ skipped
dyld: warning, LC_RPATH . in /opt/Autodesk/lib64/2021.2.1/libArriRawSDK.6.2.dylib being ignored in restricted program because it is a relative path
dyld: warning, LC_RPATH @executable_path/…/Frameworks in /opt/Autodesk/lib64/2021.2.1/framework/QtOpenGL.framework/Versions/5/QtOpenGL being ignored in restricted program because of @executable_path (Codesign main executable with Library Validation to allow @ paths)
dyld: warning, LC_RPATH @executable_path/…/Frameworks in /opt/Autodesk/lib64/2021.2.1/framework/QtWidgets.framework/Versions/5/QtWidgets being ignored in restricted program because of @executable_path (Codesign main executable with Library Validation to allow @ paths)
dyld: warning, LC_RPATH @executable_path/…/Frameworks in /opt/Autodesk/lib64/2021.2.1/framework/QtGui.framework/Versions/5/QtGui being ignored in restricted program because of @executable_path (Codesign main executable with Library Validation to allow @ paths)
dyld: warning, LC_RPATH @executable_path/…/Frameworks in /opt/Autodesk/lib64/2021.2.1/framework/QtCore.framework/Versions/5/QtCore being ignored in restricted program because of @executable_path (Codesign main executable with Library Validation to allow @ paths)
dyld: warning, LC_RPATH @executable_path/…/Frameworks in /opt/Autodesk/lib64/2021.2.1/framework/QtNetwork.framework/Versions/5/QtNetwork being ignored in restricted program because of @executable_path (Codesign main executable with Library Validation to allow @ paths)
dyld: warning, LC_RPATH @executable_path/…/Frameworks in /opt/Autodesk/lib64/2021.2.1/framework/QtXml.framework/Versions/5/QtXml being ignored in restricted program because of @executable_path (Codesign main executable with Library Validation to allow @ paths)
dyld: warning, LC_RPATH @executable_path/…/Frameworks in /opt/Autodesk/lib64/2021.2.1/framework/QtXmlPatterns.framework/Versions/5/QtXmlPatterns being ignored in restricted program because of @executable_path (Codesign main executable with Library Validation to allow @ paths)
dyld: warning, LC_RPATH @executable_path/…/Frameworks in /opt/Autodesk/lib64/2021.2.1/framework/QtConcurrent.framework/Versions/5/QtConcurrent being ignored in restricted program because of @executable_path (Codesign main executable with Library Validation to allow @ paths)
dyld: warning, LC_RPATH @executable_path/…/Frameworks in /opt/Autodesk/lib64/2021.2.1/framework/QtSql.framework/Versions/5/QtSql being ignored in restricted program because of @executable_path (Codesign main executable with Library Validation to allow @ paths)
dyld: warning, LC_RPATH @executable_path/…/Frameworks in /opt/Autodesk/lib64/2021.2.1/framework/QtSvg.framework/Versions/5/QtSvg being ignored in restricted program because of @executable_path (Codesign main executable with Library Validation to allow @ paths)
dyld: warning, LC_RPATH @rpath in /opt/Autodesk/lib64/2021.2.1/libAdpSDKWrapper.dylib being ignored in restricted program because it is a relative path
Output log to: ‘/opt/Autodesk/log/vref.log’.
Registered thread ‘CoAsyncLogger’ [ 123145342820352 ]
Registered thread ‘CoNetworkMonitor’ [ 123145343881216 ]
Registered thread ‘FastLaneServerThread’ [ 123145349185536 ]
Registered thread ‘S+W Disk I/O’ [ 123145350246400 ]
Registered thread ‘S+W Disk I/O’ [ 123145351307264 ]
Registered thread ‘S+W Disk I/O’ [ 123145352368128 ]
Registered thread ‘S+W Disk I/O’ [ 123145353428992 ]
Registered thread ‘S+W Net Input Select’ [ 123145354489856 ]
Registered thread ‘S+W Net Input’ [ 123145355550720 ]
Registered thread ‘S+W Net Input’ [ 123145356611584 ]
Registered thread ‘S+W Net Input’ [ 123145357672448 ]
Registered thread ‘S+W Net Input’ [ 123145358733312 ]
Registered thread ‘S+W Net Output’ [ 123145359794176 ]
Registered thread ‘S+W Net Output’ [ 123145361915904 ]
Registered thread ‘S+W Net Output’ [ 123145360855040 ]
Registered thread ‘S+W Net Output’ [ 123145362976768 ]
Registered thread ‘S+W Net Watchdog’ [ 123145364037632 ]
Registered thread ‘S+W Audio Processor’ [ 123145365098496 ]
Registered thread ‘S+W Audio Processor’ [ 123145366159360 ]
Registered thread ‘S+W Video (p)’ [ 123145367220224 ]
Registered thread ‘S+W Video (p)’ [ 123145368281088 ]
Registered thread ‘S+W Video (p)’ [ 123145369341952 ]
Registered thread ‘S+W Video (p)’ [ 123145370402816 ]
Registered thread ‘S+W Video (p)’ [ 123145371463680 ]
Registered thread ‘S+W Video (p)’ [ 123145372524544 ]
Registered thread ‘S+W Video (p)’ [ 123145373585408 ]
Registered thread ‘S+W Video (p)’ [ 123145374646272 ]
Registered thread ‘S+W Video (s)’ [ 123145375707136 ]
Registered thread ‘S+W Video (s)’ [ 123145377828864 ]
Registered thread ‘S+W Video (s)’ [ 123145376768000 ]
Registered thread ‘S+W Video (s)’ [ 123145379950592 ]
Registered thread ‘S+W Video (s)’ [ 123145378889728 ]
Registered thread ‘S+W Video (s)’ [ 123145381011456 ]
Registered thread ‘S+W Video (s)’ [ 123145382072320 ]
Registered thread ‘S+W Video (s)’ [ 123145383133184 ]
Registered thread ‘S+W Background I/O’ [ 123145384194048 ]
Registered thread ‘S+W Background I/O’ [ 123145385254912 ]
Registered thread ‘S+W Background I/O’ [ 123145386315776 ]
Registered thread ‘S+W Background I/O’ [ 123145387376640 ]
Registered thread ‘S+W Image Converter’ [ 123145388437504 ]
Registered thread ‘S+W Pipeline’ [ 123145389498368 ]
Registered thread ‘S+W Pipeline’ [ 123145390559232 ]
Registered thread ‘S+W Pipeline’ [ 123145391620096 ]
Registered thread ‘S+W Pipeline’ [ 123145392680960 ]
Registered thread ‘S+W Pipeline’ [ 123145393741824 ]
Registered thread ‘S+W Pipeline’ [ 123145394802688 ]
Registered thread ‘S+W Pipeline’ [ 123145395863552 ]
Registered thread ‘S+W Pipeline’ [ 123145396924416 ]
Registered thread ‘S+W Gateway connection timer monitor’ [ 123145413009408 ]
Initializing Python interpreter
Initlized Python [2.7.17 (default, Jul 14 2020, 09:26:10)
[GCC 4.2.1 Compatible Apple LLVM 9.1.0 (clang-902.0.39.2)]]
Executing command: /bin/sh /opt/Autodesk/flame_2021.2.1/bin/sanitize_shared_SynColor_transforms
/Applications/Autodesk/Synergy/SynColor/Shared/transforms …
Preserving ./J20022_State_Street_1A6C9F34-F8D7-4D25-96CE-ADFF11B9DE76
Preserving ./J20021_Coors_Snowman_1A6C9F34-F8D7-4D25-96CE-ADFF11B9DE76
Preserving ./J21002_Fiverr_1A6C9F34-F8D7-4D25-96CE-ADFF11B9DE76
Preserving ./J21003_Uber_Eats_Calzones_1A6C9F34-F8D7-4D25-96CE-ADFF11B9DE76
Preserving ./J21003_Uber_Eats_1A6C9F34-F8D7-4D25-96CE-ADFF11B9DE76
Preserving ./J21003_Uber_Eats_Every_City_15s_1A6C9F34-F8D7-4D25-96CE-ADFF11B9DE76
Preserving ./J20021_Coors_Snowman_HM_1A6C9F34-F8D7-4D25-96CE-ADFF11B9DE76
Preserving ./test_20212_1A6C9F34-F8D7-4D25-96CE-ADFF11B9DE76
Preserving ./422test_1A6C9F34-F8D7-4D25-96CE-ADFF11B9DE76
Preserving ./phil_1A6C9F34-F8D7-4D25-96CE-ADFF11B9DE76
Preserving ./tempe_1A6C9F34-F8D7-4D25-96CE-ADFF11B9DE76
Preserving ./J21999_Renderdome_1A6C9F34-F8D7-4D25-96CE-ADFF11B9DE76
Preserving ./J20025_Einstein_1A6C9F34-F8D7-4D25-96CE-ADFF11B9DE76
Preserving ./J20023_Coors_Snowman_FreCan_1A6C9F34-F8D7-4D25-96CE-ADFF11B9DE76
Preserving ./422lttest_1A6C9F34-F8D7-4D25-96CE-ADFF11B9DE76
Preserving ./uncomp_test_1A6C9F34-F8D7-4D25-96CE-ADFF11B9DE76
Preserving ./J20022_Coors_Snowman_FreCan_1A6C9F34-F8D7-4D25-96CE-ADFF11B9DE76
Preserving ./J20024_Mio_1A6C9F34-F8D7-4D25-96CE-ADFF11B9DE76
/Applications/Autodesk/Synergy/SynColor/Shared/transforms DONE
Parsing Tooltips XML
Tooltips loaded
CIP not initialized
Autodesk(R) Flame(R) Version 2021.2.1 Build 2021.2.1.255
Autodesk and Flame are registered trademarks or trademarks of Autodesk, Inc., and/or its subsidiaries and/or affiliates in the USA and/or other countries. All other brand names, product names, or trademarks belong to their respective holders.
Autodesk reserves the right to alter product offerings and specifications at any time without notice, and is not responsible for typographical or graphical errors that may appear in this document. (C) 2021 Autodesk, Inc.
BUILD DATE : Tue Feb 2 12:43:21 2021
EXEC DATE : Tue Feb 16 18:36:56 2021 - (1613522216)
CONFIG : /opt/Autodesk/flame_2021.2.1/cfg/init.cfg
POINTER : Trying wacom
AUDIO : Core Audio
MENU : /opt/Autodesk/flame_2021.2.1/menu/default.menu
Registered thread ‘Resource Manager’ [ 123145706045440 ]
Critical: <QNSWindow: 0x7fed906b08e0; contentView=<QNSView: 0x7fed906a89e0; QCocoaWindow(0x7fee702c2b30, window=QWindow(0x7fee702c1bf0))>> has active key-value observers (KVO)! These will stop working now that the window is recreated, and will result in exceptions when the observers are removed. Break in QCocoaWindow::recreateWindowIfNeeded to debug.
GRAPHICS: max texture resolution: 16384x16384
FrameBounds min resolution: 24x24
FrameBounds max resolution: 16384x16384
UI magnification: 140%
1 screen found, Xinerama is disabled
Main UI position:0,0 size:3840x2160
DVI/HDMI broadcast is disabled
Executing command: /bin/sh osascript -e ‘tell application “flame”’ -e ‘activate’ -e ‘end tell’
POINTER : Initialising.
POINTER : Initialising Wacom UD.
GRAPHICS : Supported depths: 8, 10, 12, 16fp, 32fp bits
Output log to: ‘/opt/Autodesk/log/flame202121_dxs-flame-01_app.log’.
PROJECT : J21999_Renderdome
VOLUME : stonefs
USER : randy_3
[DEBUG sgtk.ext.tk_flame_basic.bootstrap] Flame sgtk project hook waking up!
[DEBUG sgtk.ext.tk_flame_basic.bootstrap] The integration is not enabled
[DEBUG sgtk.ext.tk_flame_basic.bootstrap] Bootstrap returned ‘{‘canPushToFlame’: True, ‘flameProjectName’: ‘J21999_Renderdome’, ‘shotgunProjectName’: ‘’}’
CONFIG : /opt/Autodesk/project/J21999_Renderdome/cfg/J21999_Renderdome.cfg
CONFIG : Unknown command at line 30: Hires 24Hzf.
CONFIG : Ignoring token at line 30: Hires 24Hzf
VIDEO WINDOW: no device matching (1920,1080,10-bit 23976p, YCrCb Rec.709 4:2:2, Normal)
VIDEO WINDOW: video preview will be disabled.
PROJECT VIDEO PREVIEW: Using the following parameters for the preview device:
VIDEO PREVIEW : , channel -1, 0x0, +0, +0, , (none), 0-bit, None
VOLUMEMGT : Framestore integrity check not needed…skipped.
VIDEO : width: 1920, height: 1080, pixelFormat = 10-bit, timing: 1920X1080_5994I
MEMORY : Bytes available: 147292 MB
MEMORY : Allocated 47191 MB at address 0x18d4ff000 using mmap()
VIDEO: monitor refresh rate detected as: 60.000015
EDL Module: Portions Copyright 1991-1998 ALBA Editorial, Inc.,
All Rights Reserved.
Output log to: ‘/opt/Autodesk/log/slateDiskCacheCleaner.log’.
Registered thread ‘CoAsyncLogger’ [ 123145547300864 ]
Connected to DLmpd on 127.0.0.1 as 0:0
Connected to DLmpd on 127.0.0.1 as 0:20
Registered thread ‘CoDiskCache Cache Clean-Up Thread’ [ 123145548361728 ]
/Users/randymcentee/Desktop/A007C005_130101_R0IA.mov: No such file or directory
Could not decode video [frame 0]: LQT [util] /Users/randymcentee/Desktop/A007C005_130101_R0IA.mov: No such file or directory
I/O error: LQT [util] /Users/randymcentee/Desktop/A007C005_130101_R0IA.mov: No such file or directory (/Volumes/MVP/ManagedFolder0/82/0x02c027f6000000f0.mio origin: 1A6C9F34-F8D7-4D25-96CE-ADFF11B9DE76-GW(10.10.0.11:Gateway) node /Users/randymcentee/Desktop/A007C005_130101_R0IA.mov@TRACK(2)t0:(2)v0)
Cannot access frame 1: LQT [util] /Users/randymcentee/Desktop/A007C005_130101_R0IA.mov: No such file or directory [I/O error] [I/O error]
[flameTimewarpML] [flameAppFramework] waking up
[flameTimewarpML] preferences loaded from /Users/randymcentee/Library/Preferences/flameTimewarpML/dxs-flame-01/flameTimewarpML.randy_3.J21999_Renderdome.prefs
[flameTimewarpML] preferences loaded from /Users/randymcentee/Library/Preferences/flameTimewarpML/dxs-flame-01/flameTimewarpML.randy_3.prefs
[flameTimewarpML] preferences loaded from /Users/randymcentee/Library/Preferences/flameTimewarpML/dxs-flame-01/flameTimewarpML.prefs
[flameTimewarpML] checking existing bundle id /Users/randymcentee/Documents/flameTimewarpML/bundle/bundle_id
[flameTimewarpML] env bundle already exists with id matching current version
PYTHON : flameTimewarpML initializing
logik portal v1.4 <<<<<<<<<<<<<<<<<<<<
flame_version: 2021.2
connected to portal <<<
downloading batch setups list <<<
downloading python script list <<<
script_name: shot folder creator
script_version: 3.2
flame_version: 2021
date: 11.05.20
developer_name: Michael Vaglienty - www.pyflame.com
script_name: color timewarp shots
script_version: 1.0
flame_version: 2020
date: 08.29.19
script_name: add gmask
script_version: 1.0
flame_version: 2020
date: 01.05.20
script_name: delete folders
script_version: 1.0
flame_version: 2021.1
date: 10.04.20
script_name: encompass selected nodes
script_version: 1.1
flame_version: 2020.1
date: 05.10.20
script_name: shot sheet maker
script_version: 2.2
flame_version: 2020
date: 07.13.20
script_name: Surround Sound Channels
script_version: 1.0
flame_version: 2020
date: 11.30.20
developer_name: John Geehreng
script_name: reveal in finder
script_version: 1.3
flame_version: 2020
date: 04.12.20
script_name: replace render nodes
script_version: 1.0
flame_version: 2020
date: 02.22.20
script_name: syntheyes export
script_version: 1.1
date: 06.08.20
script_name: clip info to clipboard
script_version: 1.1
date: 09.08.19
developer_name: Andy Milkis - Michael Vaglienty
script_name: srt to xml
script_version: 1.2
flame_version: 2020
date: 10.12.20
script_name: mux freeze frame
script_version: 1.5
date: 02.10.20
script_name: export srt
script_version: 1.0
flame_version: 2020.3
date: 07.22.20
script_name: Find and Replace
script_version: 1.0
flame_version: 2019
date: 12.08.20
script_name: set in point at two sec
script_version: 1.0
flame_version: 2019
date: 12.08.20
script_name: add dated and timed folders
script_version: 1.0
date: 12.14.20
script_name: add dated system folders
script_version: 1.0
date: 12.14.20
script_name: slate maker
script_version: 3.6
flame_version: 2020.2
date: 01.10.21
developer_name: Michael Vaglienty - email: michael@slaytan.net - www.pyflame.com
script_name: PremiereXML
script_version: 1.1
flame_version: 2018
date: 01.11.21
developer_name: Ted Stanley - email: Ted@EdwardStanley.com
script_name: rename aaf clip
script_version: 1.0
flame_version: 2020
date: 10.07.19
developer_name: John Fegan
script_name: batch clear context
script_version: 1.0
flame_version: 2020
date: 09.29.19
script_name: save shots to plates folder logik
script_version: 1.0
flame_version: 2020
date: 01.14.21
script_name: new batch groups
script_version: 1.50
date: 01.17.20
script_name: create library folder template menus
script_version: 2.0
flame_version: 2020
date: 05.08.20
script_name: create export menus
script_version: 3.1
date: 01.24.21
script_name: paint node edit
script_version: 2.2
date: 01.24.21
script_name: multi batch render
script_version: 3.5
flame_version: 2020
date: 11.29.20
script_name: import fbx abc
script_version: 3.5
flame_version: 2021
date: 01.25.21
script_name: premiere xml ui
script_version: 1.0.1
flame_version: 2020
date: 01.26.21
script_name: batch node menus
script_version: 2.5
flame_version: 2021
date: 01.27.21
script_name: slates desktop copy
script_version: 1.1
flame_version: 2021
date: 02.03.21
script_name: adjust text fx
script_version: 1.3
flame_version: 2020
date: 02.06.21
script_name: find replace
script_version: 1.0
flame_version: 2020
date: 01.06.20
developer_name: Kyle Obley
script_name: clip to batchgroup
script_version: 1.6
date: 11.18.20
getting script description <<<
checking batch version <<<
current_flame_version: 2021.2
batch_flame_version: 2021.1
checking script version <<<
script_flame_version: 2021.2
logik portal loaded <<<
config file updated <<<
downloading Logik Matchboxes…
Logik Matchboxes installed <<<
clearing temp files <<<
done.
script_version: 3.2
flame_version: 2021
date: 11.05.20
script_version: 1.0
flame_version: 2020
date: 08.29.19
script_version: 1.0
flame_version: 2020
date: 01.05.20
script_version: 1.0
date: 10.04.20
script_version: 1.1
date: 05.10.20
script_version: 2.2
flame_version: 2020
date: 07.13.20
script_version: 1.0
flame_version: 2020
date: 11.30.20
script_version: 1.3
flame_version: 2020
date: 04.12.20
script_version: 1.0
flame_version: 2020
date: 02.22.20
script_version: 1.1
date: 06.08.20
script_version: 1.1
date: 09.08.19
script_version: 1.2
flame_version: 2020
date: 10.12.20
script_version: 1.5
date: 02.10.20
script_version: 1.0
date: 07.22.20
script_version: 1.0
flame_version: 2019
date: 12.08.20
script_version: 1.0
flame_version: 2019
date: 12.08.20
script_version: 1.0
date: 12.14.20
script_version: 1.0
date: 12.14.20
script_version: 3.6
date: 01.10.21
script_version: 1.1
flame_version: 2018
date: 01.11.21
script_version: 1.0
flame_version: 2020
date: 10.07.19
script_version: 1.0
flame_version: 2020
date: 09.29.19
script_version: 1.0
flame_version: 2020
date: 01.14.21
date: 01.17.20
script_version: 2.0
flame_version: 2020
date: 05.08.20
script_version: 3.1
date: 01.24.21
script_version: 2.2
date: 01.24.21
script_version: 3.5
flame_version: 2020
date: 11.29.20
script_version: 3.5
flame_version: 2021
date: 01.25.21
flame_version: 2020
date: 01.26.21
script_version: 2.5
flame_version: 2021
date: 01.27.21
script_version: 1.1
flame_version: 2021
date: 02.03.21
script_version: 1.3
flame_version: 2020
date: 02.06.21
script_version: 1.0
flame_version: 2020
date: 01.06.20
script_version: 1.6
date: 11.18.20
done.
script_version: 3.2
flame_version: 2021
date: 11.05.20
script_version: 1.0
flame_version: 2020
date: 08.29.19
script_version: 1.0
flame_version: 2020
date: 01.05.20
script_version: 1.0
date: 10.04.20
script_version: 1.1
date: 05.10.20
script_version: 2.2
flame_version: 2020
date: 07.13.20
script_version: 1.0
flame_version: 2020
date: 11.30.20
script_version: 1.3
flame_version: 2020
date: 04.12.20
script_version: 1.0
flame_version: 2020
date: 02.22.20
script_version: 1.1
date: 06.08.20
script_version: 1.1
date: 09.08.19
script_version: 1.2
flame_version: 2020
date: 10.12.20
script_version: 1.5
date: 02.10.20
script_version: 1.0
date: 07.22.20
script_version: 1.0
flame_version: 2019
date: 12.08.20
script_version: 1.0
flame_version: 2019
date: 12.08.20
script_version: 1.0
date: 12.14.20
script_version: 1.0
date: 12.14.20
script_version: 3.6
date: 01.10.21
script_version: 1.1
flame_version: 2018
date: 01.11.21
script_version: 1.0
flame_version: 2020
date: 10.07.19
script_version: 1.0
flame_version: 2020
date: 09.29.19
script_version: 1.0
flame_version: 2020
date: 01.14.21
date: 01.17.20
script_version: 2.0
flame_version: 2020
date: 05.08.20
script_version: 3.1
date: 01.24.21
script_version: 2.2
date: 01.24.21
script_version: 3.5
flame_version: 2020
date: 11.29.20
script_version: 3.5
flame_version: 2021
date: 01.25.21
flame_version: 2020
date: 01.26.21
script_version: 2.5
flame_version: 2021
date: 01.27.21
script_version: 1.1
flame_version: 2021
date: 02.03.21
script_version: 1.3
flame_version: 2020
date: 02.06.21
script_version: 1.0
flame_version: 2020
date: 01.06.20
script_version: 1.6
date: 11.18.20
done.
Looks like it’s a permissions thing. You need admin permissions to write into /opt/Autodesk/presets. Maybe in the next version of the portal I can add a pop-up for the password to allow writing into that folder. Are you able to download the matchboxes to a non Autodesk folder?
So if I try to go into /Users/randymcentee/Downloads/logik, for example, this happens…
It only downloads these…!!!
Yeah, okay, actually, in a minute or two they all show up. :slight_smile:
Hi. On my side, I still can’t have Portal working.
I install it, open it in flame but every tab remains empty. 1st tab, only the python scripts I installed manually show up on the left part but nothing on the right part.
On the 3rd tab, I don’t see any of the community batch setup.
Can’t understand why… Any idea
Do you get any errors in the shell?
Nothing either in Flame’s message history or in the Portal bottom window.
Anywhere else I should have a look?
OK, actually, I’ve got that in the terminal… IMG_6354|666x500
If I check, I don’t have a “python” folder in my /opt/Autodesk/user/pl2020 directory…
Gives me the same on Mac… … :frowning: nothing shows up…
I just posted a new version of the script. Give it a shot. I think I may had inadvertently broke something when I made a fix to a different problem in the last version. Let me know if this works better for you.
Mike
