Thanks a lot for the portal and all those great scripts you made available to us
I get an error message with the latest version. Any idea what might be causing this?
No scripts are shown to install (Batch and Archive seems to be fine).
Logik Portal execute callback [<class ‘logik_portal.LogikPortal’>((<flame.PyClip object at 0x7f62983e3d60>,),)] failed because of an error of type ParseError(‘not well-formed (invalid token): line 1, column 1’)
→ clearing temp files
I added the older version to the Logik Portal page. I’m thinking I might also do this for some of the other scripts I recently updated to only work with 2022 and later just in case people haven’t updated yet.
I dont know if you made the Uber save py. is it posibble to make it save to 2 or 3 different places in just one click? … Why? we are saving our batch setups mostly to the server, but could be cool to save it to its actuall projects too in one click
I was using create shot setup in flame 2022.3. Now we upgraded to 2023. Updated the create shot setup too. I can use it but it is not creating folders anymore. Everything is the same as before. Am I doing something wrong I dont know?!?!
Just posted a new version of the Logik Portal (v5.0) with a few minor updates and a pretty important one. I’ve increased the maximum size of the archives that can be uploaded to it to 1 GB. Starting wih Flame 2023.2, python scripts that come with Flame that are in /opt/Autodesk/VERSION_OF_FLAME/python_utilities/scripts are now listed in the Portal and can be installed through it.
Most importantly, I’m switching the hosting service that the Portal uses. Due to this, after February 28th, 2023 versions prior to v5.0 will no longer work.
As of right now uploading python scripts, batch setups, and archives no longer works with prior versions. Any uploading has to be done with v5.0. Any new versions of scripts, batch setups, or archives that are uploaded will only be available in 5.0. Old versions of the Portal won’t get updated with any new uploads.
The new version of the Portal can be had here:
or here:
I’ve also added some minor updates to these scripts on the Logik Portal:
Adjust Text FX
Color Timewarp Shots
Delete Folders
Encompass Selected Nodes
Multi Batch Render
Refresh Python Hooks
Reveal Path
Shot Sheet Maker
SRT to XML
Sorry for the delay in answering this. I’ve been doing some work switching the hosting for the Portal. Anyone wanting to upload to the Portal will need the latest version of it, v5.0. Then to upload a batch setup or archive to the Portal they can do that by just hitting the submit buttons in either tab. To upload python scripts anyone who wants to do that will have to email me to get a login. That login info will have to get entered into the Portal after hitting submit in the python scripts tab. I’m only requiring this in the case of python scripts to try to limit the chances of someone uploading a malicious script. Not that anyone here would do something like that, but you never know.
I just updated a couple of scripts on the Portal for anyone interested.
Import Camera v4.6:
Fixed bug where Alembic files couldn’t be imported.
Added ability to setup a tokenized path to get to FBX/Alembic files easier. This is set in the script setup. Flame Main Menu → pyFlame → Import Camera Setup. By default it’s set not to use this and to have to navigate to find FBX/Alembic files.
Shot Sheet Maker v3.5:
By using any of the following names for a column name, the corresponding clip info will be added to the cells in that column. For example, if you want to add the Shot Name to a cell, name the column ‘Shot Name’ and the shot name will be added to the cells in that column. Column names can be edited by clicking on the Edit Column Names button.
Shot Name
Source Name
Source Path
Source TC
Source TC In
Source TC Out
Record TC
Record TC In
Record TC Out
Shot Length
Source Length
Comment
I’ve just posted a new version of the Logik Portal for anyone interested. I’ve done some updates to the Matchbox tab. It now lists all the available Logik matchboxes with their type and descriptions whether or not you have the whole collection downloaded. The order of the list can be sorted by Name, Type, Author. Single Matchbox nodes can be also be added directly into batch from the Portal without having to install the whole collection.
Also just a reminder, versions of the Portal earlier than 5.0 will stop working at the end of February.
