MacOS - Minimum desktop effects
I’m moving from linux to mac for my main flame machine. I don’t care for the fancy desktop animations and I want as much speed as possible when moving around on the desktop, moving windows, etc.
I have checked “Reduce Motion” in the Accessibility Settings. Are there any other options to check for maximum speed vs. frilly frill?
Here are some of my prefs on Mac:
Keyboard - Key Repeat Fast
Dock Settings - Minimize window using
Mission Control - When switching to an application, switch to a Space… (check) - I think you need this for Flame if you have multiple screens. I have it on all my systems.
You might consider turning hot corners off
All good stuff Sinan!
I’ve never known about this feature. How much of a difference do you think it makes to improve Flame’s performance?
Make sure you don’t let spotlight index your framestore or any other drive that you depend on for maximum throughput.
Test it. $5 says it’s immeasurable. Ya take Venmo?
I think you are right. I just turned it off and I couldn’t feel or see a difference. Although jumping between spaces now it dissolves instead of slides.
I definitely see some improvement when working over Teradici. When there’s lots of desktop ‘animation’ I see Teradici struggle to keep up. But then again Teradici struggles just to play back 23.98 HD for me anyway.
