Anyone having issues with the new version and Logik Portal. I’m getting cannot connect to portal. check internet connection and try again.
I just installed it on my Linux box with 2024.1 with no problems. Downloaded the Matchbox set from it and worked all right.
It should be working. Make sure you have the latest version of the Portal. I changed the back end server hosting it earlier in the year so if you’ve got an older version of the Portal it probably has the old server info.
Mike
thanks. I was at v4. Loaded current and all is good.
