Slow response on wacom intous pro
Experiencing slow response time on a Wacom intous pro flame 2025.1 Linux. Other Flame seems to be working correctly. Exact same settings as other Flames, tried swapping usb ports checked the xorg.conf. The problem even persists if I swap out Wacom tablets. Any Ideas?
Do you have more than one OS installed?
Is the mouse responsive or just as flaky?
It’s the Wacom tablet, not mouse. I changed the pressure threshold to 10% and used Mouse cursors. It’s a little bit better, I just notice when I move a node it seems to move behind the cursor a bit. Laggy.
I ask because if the mouse is problematic also, it might be an issue with the extenders.
Have you tried swapping tablets and or pens?
No extenders. Workstations are local to each bay.
I have swapped them to different USB ports.
I mean did you try using a different tablet or pen?
And yes, I have swapped wacoms too.
