Total duration of a clip with several and overlapping segments
Hello
would like to determine the total length of a clip consisting OF several and overlapping video and audio segments (if possible in seconds).
Holding ALT(Option) on the keyboard and clicking on the segment does only show the duration/length of the selected clip.
Is there a better approach?
How can frames be convered into seconds?
Thank you!
Joe
In a timeline, the fastest way is to mark and In and and Out and use the “Dur” field to find the duration. Control + Alt + T changes between frames and seconds in all fields regarding duration.
Thank’s Randy,
works like a charm!
You can select multiple clips on the time line then use the hotkey ’ for flame, or Shift / for smoke and it will mark an in and out around the selection.
