We have 2 Flames here and I need to move some stuff from one to the other.
If I look at Flame 3 from Flame 1, I can’t see any of Flame 3’s projects when looking at projects under the Autodesk Network.
When I look at Flame 1 from Flame 3 through the Autodesk network, I see Flame 1’s projects, however If I try to push anything to Flame 1 from Flame 3, the destination library is locked. If I try acquire write access, it says "cannot acquire exclusive write access. Locked by ‘Flame’ on ‘flame1’
Yeah, you should be able to pull pretty much at will. You have something going on with your networking or permissions. Sometimes it gets dumb after a reboot. Quit flame on both machines and do “systemctl restart autofs nfs” (no quotes) as root and then try again?
I get:
Job for nfs-server.service failed because the control process exited with error code. Se “systemctl status nfs-server.service” and “journalctl -xe” for details
