Wouldn’t it be nice if also…
Having just read Marcus’ post apologies for hijacking your header (and EDIT just seen the long thread on paint)! I’ve had a bugbear about paint for a while. Those times when you’ve not switched to sequence for multiple paintstrokes and have to individually turn over each stroke from single frame to sequence… Is there a feature request this or a solution that doesn’t involve a python script? It’d be great to have the ability to select multiple and then change the range.
You can add your vote to FI-00864
